| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Here's what I did, based on my idea of the current mirors. The output voltage is approx 2V RMS, and the Zout is 300R I haven't build it yet. But the simulations give good results. WARNING: this I/V won't work with a TDA1541, because the input voltage is fixed to 0.7V. If you want to use another DAC with this I/V, check that the voltage compliance is high enough. The output has to be AC coupled, since there's a big offset on the 300R resistor. A 0.5W is recommended for this one. Use your favorite PNP transistor for everything, but they all have to be the same. Matching them can also help. The courrent source can be what you want, a BJT, some JFETs, an IC... PS voltage should be between 12 and 17V |
#2 |
I'm afraid the 1543 won't like to have its output tied to 0,7V.
The linear region is IIRC from 1,8V to Vcc-1,2V. Your idea is nice but needs to be refined Cheers Andrea |
#3 |
Oops
#4 |
Couldn't you just put a LED with 1.2 v in between the first transistor and the current input, assuming that I3 is in. Since it is current driven the varying voltage shouldn't matter that much, smaller than for a passive IV anyway.
Do not know the 1543 but since the voltage will be fixed by the led and transistor (releatively at least) couldn't you replace the resistor R1 with a current source. Alternatively if you use a current source you could add emitter resistors on all transistors, reduces the matching problem i think. Edit: Saw now that the minimum linear voltage was 1,8 so use a 1,9v LED instead.
Hjelm |
#5 |
A current mirror like this might work better, tough I'd use a resistor to Vcc as load for the mirrored current, choosing its value so that it sets the collector of the 4 parallel Bjts at about half Vcc when there is digital silence.
Don't feel the need for R1 either, since the TDA has its internal current sources... Cheers Andrea |
#6 |
Andy:
This would fix the voltage at 3*Vbe?
Hjelm |
#7 |
You need R1, since you can't connect the TDA from Q1's base (in your schematic) to Vcc
#8 |
Might be that i do not know the TDA but do you really need to connect the current out to vcc?
Hjelm |
#9 | ||
Cheers Andrea |
#10 |
Andy, yous curent miror works. The good thing is that the input voltage is now 1.8V
The "bad" thing is that now, the TDA sees much more AC voltage at its output. I'll try cascoding Q1, but I'm not sure it will work. Since Q1 is only a diode, cascoding a diode ... |
| gainn stage for tda1543 dddac fet? | spgjmf | Digital Source | 3 | 7th February 2009 10:17 PM |
| Sowter transformer 8347 I/V stage fot TDA1543 | elec-tron2 | Digital Source | 20 | 9th June 2007 07:46 PM |
| Vacuum Tube I/v Analogue Stage For Tda1543 | aht | Digital Source | 9 | 13th July 2005 01:16 AM |
| Low value IV resister followed with high gain amp stage?[tda1543] | setmenu | Digital Source | 10 | 27th September 2004 01:14 PM |
| Looking for an active I/V stage for TDA1543-based DAC | IpsilonSound | Digital Source | 21 | 17th June 2004 08:34 PM |
| Page generated in 0.10280 seconds (78.09% PHP - 21.91% MySQL) with 11 queries |
