| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
I've just completed the DAC based on the schematic from the RJM site - music has got detail and vocals sound fine but bass is very much lacking. Component values used are as specified. Tried increasing the power supply cap to 1000uf, dropped the 1543 supply voltage to 8V and still no difference. Any idea what's happening ? Appreciate the help. Thanks. Schematic link below.
http://www.geocities.com/rjm003.geo/...o/diy_dac.html |
#2 |
Yo! Fancy seeing you here...
What are you connecting the dac to? Try posting on echoloft, and see if any of the local kaypohs can help.
#3 |
Hey There,
I have the same problem, I connect it to my Marantz CD4000 and the bass and the 3d image is not very good. My Sony CDP-195 is unmodify and sound much beter..... I don't know what the problem is. Please Help |
#4 |
A possible answer is that the passive I/V output is having problems driving the next stage (the preamp, or worse the passive attenuator). I had that issue, and it was solved by having a buffer on my gainclone, and using parallel dacs.
#5 |
I get tremendous bass drive out of my DDDAC 1543...I am using the 8 parrallel chip configuration which produces plenty of drive...also...I liked the effects of reclocking with Guido Tent's reclocker.
#6 | |
Mads K |
#7 |
Passive I/V can also have good bass, but the choice of components is more critical. The battery improves bass substantially as well.
I can't complain that my passive I/V stage is lacking in that dept. Actually, I was commented that the bass was rather amazing. I'd say that PS is quite important for good bass performance. |
#8 |
Hey There,
I have fix my problem... Before the transformator i had a AC filter self made it and i have cut the filter and know it sound amazing so good so fast so clear...... I have just finished my Clone of the Bottlehead Foreplay its just amazing how this al sound together....I am sorry for my English.... My setup: Marantz CD4000 Cd-Player Cs8412-Tda1543 (all caps are marcon) Dac Bottlehead Foreplay Pre-Amplifier John Linsley Hood Amplifier Vifa 2-way (D27TG+17WP) Speakers |
#9 | |
Banned
Are you familiar with the Jon Risch filter?
#10 | |
| Dipole bass or Ripole Bass? | MJL21193 | Subwoofers | 13 | 15th September 2008 07:42 AM |
| any electric bass players? im building a bass guitar cab | KOA | Instruments and Amps | 27 | 30th April 2007 03:49 PM |
| DBA (dual bass arrays) and active bass traps | capslock | Subwoofers | 3 | 20th August 2006 12:52 PM |
| 32 ohm bass amp. | Tweeker | Tubes / Valves | 5 | 9th March 2006 12:43 AM |
| For all Bass Junkies out there (Behringer Bass processor usage report) | VEC7OR | Digital Line Level | 5 | 27th October 2003 09:18 AM |
| Page generated in 0.09965 seconds (81.00% PHP - 19.00% MySQL) with 11 queries |
