Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Rotel RCD971 PCM63 output filter question
Old 2nd February 2018, 02:04 AM   #11
Ken Newton is offline Ken Newton  United States
Ken Newton's Avatar
Op-amp U702 doesn't appear to be connected as an I/V transimpedance amplifier, it instead appears to be connected as an simple inverting voltage amplifier having a gain of (3.9k / 100R = 39). The DAC's current output feeds the 100R op-amp input resistor on one side, and has a virtual ground node on the opposite side. So, the 18.2nF of capacitance from the DAC output to ground is effectively in parallel with the 100R input resistor, and therefore forms a low-pass filter with it. The cut-off frequency looks to be around 87.5kHz.
The output current of the DAC will develop a voltage across the 100R input resistor, which then would be multiplied by the x39 gain of the amplifier.
Old 2nd February 2018, 07:38 AM   #12
Mooly's Avatar
I felt that the numbers didn't really sound right for the stage to be an inverting amp tbh although the configuration could be either with a value as low as 100 ohm.
One way to tell would be to deliberately increase the 100 ohm. If the DAC was giving a voltage output then the output from the opamp would change as expected. If it was a current output then changes in the 100 ohm (within reason) would not show a change in output voltage at the opamp output, but would instead show a voltage change at the DAC output pin as the current developed a voltage across the resistor. The final output voltage would not change though for the 'current' theory.
Rotel RCD971 PCM63 output filter questionHide this!Advertise here!
Rotel RCD-971: Anyone revised the PCM63 Current Output Config-Source of DC Offset??? dtm1962 Digital Source 3 25th November 2010 08:39 PM
Rotel RCD971 won't eject when empty corbijn Digital Source 7 22nd October 2010 07:35 AM
Rotel RCD971 warpig Digital Source 12 25th June 2009 09:23 PM
Rotel RCD971 reading problem - assistance/advice needed fixilator Digital Source 5 13th September 2008 10:32 AM
Rotel RCD971: Which Opamps in I/V Converter & Output Stages? dtm1962 Digital Source 23 11th March 2008 04:27 PM
