Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 6th April 2004, 08:24 AM   #1
mrstone is offline mrstone  Hong Kong
Question TDA1541 + I/V Output Transformer
Hi Folks,
In transformer-coupled I/V stage, a resistor (around 20 ohm) will be used to terminate the Idac output and then couple to a step-up transformer.
However, at idle stage (silence, no signal), TDA1541 have sink current at the output.
So, my question is: Will this sink current saturate the step-up transformer? Any transformer in the market can be used and is suitable for this purpose?
Your suggestions and comments will be appreciated! Thanks!!
Cheers
Mr. Stone
Mr. Stone
Old 12th April 2004, 04:55 PM   #2
Pls help.
Mr. Stone
Old 12th April 2004, 09:32 PM   #3
dddac is offline dddac  Germany
No problem.......
there are specially wound transformers for this purpose. Like the Sowter 8347 1:18 TX. Goes very well, I have built 3 applications with it with Current outputs and it works just fine....
tc
doede
Old 12th April 2004, 10:13 PM   #4
guido is offline guido  Netherlands
guido's Avatar
Use two dac's, feed one with inverted signal. Each has the resistor to gnd. Then connect the transformer between the resistors. No DC over the transformer.
Greetings,
GuidoB
Old 13th April 2004, 03:23 AM   #5
Hi dddac, guido and all,
Could I use Amplimo Signal transformer type TM3? as it's much cheaper than Sowter...
Actually, I send email to Amplimo and asked for the spec, but up to this moment, I still haven't received any response from them....anybody can share your experience on it?
Thanks so much!!
Mr. Stone
Old 13th April 2004, 05:12 AM   #6
Greetings,
Good trick Guido, as extra bonus you have extra output voltage. One point: Output impedance increases by 4x ...
with the sowter = 14k. Should be ok for most apps...
tc
doede
Old 13th April 2004, 05:13 AM   #7
Thanks so much!!
I don't know this one.... sorry, just try it I would suggest?
tc
doede
Old 13th April 2004, 10:21 AM   #8
guido's Avatar
From the website:
Signal transformer type TM3 Euro 26,47
Never try to check the windings with an ordinary multimeter. The DC-current of the meter will magnetise the core!
Ratio
1 : 15
frequencyrange +3dB
30 - 25000 Hz
max. input at 30Hz.
800mV
to connect primary
microphone of max. 200 Ohm
to connect secondary
min. 45 kOhm
primary wires
green - grey
secondary wires
red - blue
lead length
70mm
max.voltage between prim. and sec. winding
100V
dimensions excl. screwthreat
22 x 23mm (diam x height)
Greetings,
GuidoB
Old 16th April 2004, 08:19 AM   #9
Mr Stone,
Have you used the Amplimo Signal transformer type TM3 ?
What are your findings ?
firestorm
Old 16th April 2004, 11:00 AM   #10
rbroer is offline rbroer  Netherlands
rbroer's Avatar
My findings:
The TM3 is physically smaller, and output voltage collapses quite easily.
IME, sweet sound, but bass and dynamics suffered using either stepup transformer, TM3 being worst. YMMV.
Also experienced hum problems that I could only solve by giving up galvanic isolation.
In the end too low output for me when using Riv of 22 ohms for
TDA1541 In this setup, the TM3 had almost no output, much less than one would expect when comparing the 18* and 15* stepup ratios.
My preference clearly goes to the Sowter 8347 1:18 TX
Rudolf Broertjes
Improvements to TDA1541 dac output stage? sharpi31 Digital Line Level 15 9th February 2009 07:53 AM
Adding secondary of output transformer into cathodes of output stage ? Eico ST-70 freddymac406 Tubes / Valves 3 21st April 2007 06:15 PM
Yet another output stage for TDA1541 mevangel Digital Source 6 21st November 2004 08:21 PM
How many TDA1541(A) in parallel without output baffer? iklari14 Digital Source 0 7th August 2003 11:34 AM
First DAC project ,TDA1541 current output George Kubitsch Digital Source 8 6th December 2002 04:30 PM
Page generated in 0.12471 seconds (82.76% PHP - 17.24% MySQL) with 10 queries
