| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
HI!
I have built the "Elektor DAC 2000" some time ago. Efter modding it with AD797 instead of OPA627 the sound has improved a great deal. I would like to have switchable tube output though. Like the Shanling CD-players. I need advice on: 1. What kind og tube design to add (SSRP, etc. 2. What kind of tubes. I have a few 12B4A, 6N1P, E80CC to try out. 3. Where and how to break in to mu exsisting circuit to add the new tube output. Any ideas? Best regards, Peter Lund |
#2 |
I am building the same Dac, and I plan to use a relay from Iout (pin 14)from the Dac so I can switch beetwen the two outputs.
I am going to use a SSRP with 6SL7,and the simple solid state I/V converter from this forum. |
#3 |
Do you have any schematic for your tube output stage that you want to share?
#4 |
Ryssen,
Take a look at this schematic: http://mparvi.republika.pl/DAC2sig_small.gif It's a tube preamp output stage from an Audio note DAC with ECC88/6DJ8 in SRPP config and low voltage. Sound is said to be excellent. What about adding it after the V-I stage? - Peter |
#5 |
The Ecc88 should work as well,I use 6SL7 because I like it better,
Here are some posts that I´ve done on the outputstage Tube outputstage I am going to use this stage with 6SL7. Easy-to-build I/V stage I am going to try this I/V stage might work with the IC one on the board but you better ask sommeone who knows better than me,might be interesting for me to know to...... |
#6 |
The Thorsten Loesch tube dac project looks nice.
I just don't get if the V/I-stage is needed or if you can connect it straight to pin 14 of the PCM1704? - Peter |
#7 |
I had a Ecc83 SRPP on my Pioneer PDS904,connected direct from the DAC,The sound was quite well,I don´t think it will do any harm to
try it without I/V stage,someone correct me if I´m wrong. |
#8 | |||||
Previously: Kuei Yang Wang
Konnichiwa,
I personally use something rather different in a commercial mod set for Shanlings Tubed CD & SACD Player, but that circuit will not be available in the public domain. It provides great sound and excellent technical performance (Zout around 100Ohm, Frequency Response well into the MHz range, THD with WE396A is around 0.05 to 0.1% at digital full scale, less at lower levels), but the good old SRPP is not a bad choice, especially if the load is low. Quote:
Alternatively, if you wish to have both stages operational you could add a resistor (same value as intended I/V Resistor for Tube section) in series with inverting input of the I/V Op-Amp after the DAC. However, this does not remove the Solid State circuitry from the signal path and hence the Valve Stage will retain a trace of "solid state" sound. I tried this forst for my Shanling Mod's as I intended to leave the solid state stage in place. I found it compromised the sound much more than I was happy to accept, so my mod's to the Shanlings dispose of the SOlid State section completely (the headphone Output is gone too). Sayonara |
#9 |
xxx
#10 |
Just to be sure that why are talking about the same circuit, I am attaching the Thorsten Loesch tube dac.
/ Peter |
| SS or tube voltage amplifying stages in an amp with tube output? | ray_moth | Tubes / Valves | 14 | 4th July 2007 03:09 AM |
| need diy tube preamp (line-stage) recommendation and general tube advice | Musiclover4 | Tubes / Valves | 15 | 24th November 2005 01:19 AM |
| Output Tube biasing for Toroidal Output Transformer | gingertube | Tubes / Valves | 7 | 17th April 2005 04:40 PM |
| Tube output buffer for DAC....needs advice! | jazzpeter65 | Tubes / Valves | 0 | 4th April 2004 10:48 AM |
| tube cd output advice | Raj1 | Tubes / Valves | 18 | 4th October 2003 07:57 PM |
| Page generated in 0.12426 seconds (81.34% PHP - 18.66% MySQL) with 11 queries |
