Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
DIY tube output in DAC - needs advice...
Old 8th April 2004, 10:26 PM   #11
Ryssen is offline Ryssen  Sweden
Ryssen's Avatar
Its the one Im talking about,but I am going to leave out the R1
C1 and deem.
Old 8th April 2004, 11:31 PM   #12
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
Those two alone aren't responsible for the de-emphasis IMO.
Where's the I/V done? Isn't that what's R1 for?
What's the B+ for the SRPP? Is it tightly regulated?
Frank
Old 9th April 2004, 12:51 AM   #13
Ryssen's Avatar
For Deem I am going to leave out R2 C2 relay and the 470K resitor.
Yes its in R1 the I/V is done,but if I use the Easy-to-build I/V stage i was going to leave out R1.
I thougt of using the same B+ as I did with my SRPP for my PDS904 witch is regulated at ca 250v.
Old 9th April 2004, 07:33 AM   #14
jazzpeter65 is offline jazzpeter65  Denmark
Thumbs up Why leave out R1?
Ryssen,
Why do you want to use an active I/V converter circuit when the same function can be made by a simple resistor?
I think the whole idea of a simple analog output gets lost if you use an opamp for I/V. Most DACs exspect to send current into a virtual ground. In most cases in form of an opamp.
A load resistor is a more simple way to do this, but its not working with all DACs. Multibit DACs are not a problem, though. PCM1704 is multibit DAC. A load resistor will give less distortion than using an opamp. IMHO you should keep R1 since its a clever way of keeping the signalway short.
/ Peter
Old 9th April 2004, 07:36 AM   #15
The PSU for this DAC tube stage is not regulated. Wouldnt is be better to use tube regulation? In the end, the PSU is what we listen to.......
/Peter
PS>I have attached the original PSU.
Old 9th April 2004, 07:38 AM   #16
Something like this maybe?
Old 9th April 2004, 07:40 AM   #17
Or this?
Old 9th April 2004, 11:06 AM   #18
Ryssen's Avatar
I agree that a resitor is simpler (shorter way) of doing I/V convert.
I got this advise "Try it, you won't be sorry" in this thread:http://www.diyaudio.com/forums/showt...=&pagenumber=9
Question number 2:I have read somewhere It sometimes sound
better with the right (Different value on the resistor)would it be possible to use variable resistor to find the right value?
won`t solidstate regulators be better since they do not display any symtoms of noise?
I am thinking about it 2
http://www.diyaudio.com/forums/showt...threadid=31447
Old 9th April 2004, 12:43 PM   #19
ThorstenL is offline ThorstenL  Germany
Previously: Kuei Yang Wang
Konnichiwa,
May I suggest to all involved to re-read (or read) my short essay on Tubes and Digital from which these schematics are taken?
Thermionic Valve Analogue Stages for Digital Audio
I hope this will answer most questions sufficiently. You might also find some other essays and projects presented on my pages informative in the context, so please have a look:
the Thunderstone Audio Website!
Any remaining question, please ask in this thread.
Sayonara
Old 9th April 2004, 09:55 PM   #20
Sayonara,
I have read your arcticles and so far, I get most of it. I have a few questions though, before I start building>
1. Would a regulated solid state PSU give a better signal-to-noise ratio? See attached circuit.
2. PSU: Can I substitute the special resistors for normal ones?
3. What do I have to change to use E80CC or 12Bb4H?
- Peter
DIY tube output in DAC - needs advice...Hide this!Advertise here!
Tube output buffer for DAC....needs advice! jazzpeter65 Tubes / Valves 14 20th June 2013 03:50 AM
need diy tube preamp (line-stage) recommendation and general tube advice Musiclover4 Tubes / Valves 16 18th May 2013 03:19 PM
SS or tube voltage amplifying stages in an amp with tube output? ray_moth Tubes / Valves 14 4th July 2007 03:09 AM
Output Tube biasing for Toroidal Output Transformer gingertube Tubes / Valves 7 17th April 2005 04:40 PM
tube cd output advice Raj1 Tubes / Valves 18 4th October 2003 07:57 PM
Copyright ©1999-2017 diyAudio
