Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Philips CD960 problems
Old 7th December 2017, 01:03 PM   #11
ClassA is offline ClassA  Taiwan
Thanks. I have replaced all old caps and broken diodes on the power supply board but nothing changes. What is the most possible parts needs to be checked first on the servo board?
Old 7th December 2017, 01:41 PM   #12
lcsaszar is offline lcsaszar  Hungary
As other also suggested, please measure the power supply voltages. You will need a service manual or at least the circuit diagram. Marantz used to have the good habit of packing the schematic diagram with their appliances, and Philips CD-960 is identical to Marantz CD94.
BTW how did you manage to break those diodes?
Old 10th December 2017, 02:12 PM   #13
The diode issue is visible. It was broken into two parts. I just replaced it with a new one.
Old 10th December 2017, 02:22 PM   #14
ColinA123 is offline ColinA123  United Kingdom
There is a 960 on Uk E-bay.
Serviced Dec 2017.
Does this mean they tweaked the laser power to get it playing and are looking to move it quickly?
Or am I bitter and twisted?
Old 11th December 2017, 12:56 PM   #15
Can anyone tell me what the normal 1K VR setting(?ohm) is for CDM1?
Old 11th December 2017, 01:13 PM   #16
The 1k is the laser current setting. It does not need any adjustment. If absolutely necessary, follow the service manual:
Play the test disc
Measure voltage on R309
Adjust VR 3180 for 575 mV +/-75 mV on R309
If you don't have a test disc, better not to touch it.
Old 12th December 2017, 12:52 PM   #17
Do you know the typical resistance setting for the 1K VR?
Old 12th December 2017, 01:36 PM   #18
Mooly's Avatar
There is no typical setting, it depends solely on the optical output of the laser diode and the current needed to produce that level of intensity.
Old 13th December 2017, 01:32 PM   #19
What will the 1K VR resistance be for a new CDM1?
Old 13th December 2017, 01:35 PM   #20
Mooly's Avatar
You are really not understanding the issue here.
A new laser diode has a very wide tolerance on the current required to produce a given optical output and this means the correct current could be anywhere from say 45 to 65 milliamps as an example. That might be a range of 300 to 600 ohms on the preset.
It is not possible to give a typical figure simply because there isn't one.
Philips CD960 problemsHide this!Advertise here!
Help with Philips CD960 muizel Digital Source 14 17th August 2017 02:55 PM
Philips CD960 Query Gravissima 64 Digital Source 8 19th August 2010 04:38 PM
philips cd960 vs 850mk2 torim Digital Source 0 20th January 2010 11:32 AM
Help me mod Philips CD960 @lf Digital Source 21 11th December 2006 07:21 PM
Philips CD960 diyman Digital Source 0 1st November 2005 01:50 PM
