| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
I recently acquired an NEC 602 cdrom drive. I would like to entirely remove the S/PDIF interface from the output. As per a suggestion in this thread :
Schematics for NEC 602 CDROM Drive? I would like to hook up the LRCLK, DATA and SIN outputs from the Sony CXD2510 IC directly to a TDA1543A. However, I can't find any TDA1543A's for sale. Are their any replacements which can take the same Sony data format on input and sound at least as good? If not, what other options do I have open to me? Additionally, would a 74x IC buffer on input of the TDA1543A be of any benefit? I believe it was said that the digital signal on the DATA line is not as clean as it could be coming out of the CXD2510. |
#2 |
MCM electronics has the TDA1543s in stock
#3 |
MCM just carries the TDA1543 NOT the A-model. The difference is that the former takes input in the I2S format and the latter uses data in Sony's EIAJ format. I would rather not have to use any conversion circuitry.
#4 |
don't the cristal/AD/TI chips accepd sony's format?
#5 |
From looking at the datasheet for TI's PCM1792 it gives the list of supported formats as:
16-, 20-, 24-bit standard (right-justified) format 24-bit MSB-first left-justified format 16-/24-bit I2S forma Is the the EIAJ (CS-340/CS-1201) standard among these? |
#6 |
Try www.lobtron.de, shipping price EUR 6 to North America.
#7 |
TDA1543A accepts 24bit right adjusted format which data is 16bit two's complement with MSB first.
I have tried other formats, it doesn't work.
Waiting for weekends every day |
#8 | |
ray. |
| CXD3003R and TDA1543A | rekin | Digital Source | 4 | 16th November 2007 11:39 AM |
| Tda1543a S1 | cm | Digital Source | 26 | 24th June 2005 06:46 AM |
| Fs: Tda1543a-s2 | rbroer | Swap Meet | 6 | 21st June 2004 11:29 AM |
| Wanted: Tda1543a | Tor M | Swap Meet | 11 | 30th January 2004 05:50 PM |
| Tda1543a | DonJuan | Digital Source | 31 | 28th January 2004 06:39 PM |
| Page generated in 0.09691 seconds (73.86% PHP - 26.14% MySQL) with 10 queries |
