Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Cyberhome CH-DVD 452 (DVD452) - Screen and St-By Light goes blank
Old 29th November 2017, 10:05 AM   #1
tiefbassuebertr is offline tiefbassuebertr  Germany
tiefbassuebertr's Avatar
Default Cyberhome CH-DVD 452 (DVD452) - Screen and St-By Light goes blank
Basically, this is based on a defective switching power supply. But on my two devices of the same model power supply provides all voltages with correct values (all electrolytic capacitors on the SPS-PCB already replaced).
If I open the tray (drawer) without connecting mains plug in the wall power outlet, closes the tray 5 seconds after plugging in the mains plug, but without lighting up of display and StBy LED and without any command acceptance.
Thus there are still the following possibilities:
1) damaged MPEG audio-video decoder chip
2) faulty local voltage regulation on the MPEG main board
3) RESET procedure necessary (maybe the most likely cause, but I don't find the according instructions)
Maybe this is a known bug of this model and maybe there is a schematic diagram available anywhere.
Thank you very much for advices in advance.
P.S. under
BBK DV718SI SM Service Manual download, schematics, eeprom, repair info for electronics experts
you will find the service manual of BBK's DV718SI, where the same MPEG video-audio decoder is in use (MT1389).
In the flow chart for "Power Not On" troubleshooting on page 34 to page 38 there are helpful advices.
The schematic of the DVD452 from Cyberhome would transform this troubleshooting to an easy task. Unfortunately this schematic I haven't.
Old 17th March 2018, 10:59 AM   #2
Default Pre-Programmed Failure Date on DVD Players?
I have heard, that there are several dvd player brands with pre-programmed failure date. Maybe this is just the case by this brand.
Since I now know many people who have the same problem as described in post #1, this could indeed be the case.
Cyberhome CH-DVD 452 (DVD452) - Screen and St-By Light goes blankHide this!Advertise here!
To Screen or not to screen Vbe multiplier leads in HK1400 db0360 Solid State 2 13th August 2014 08:17 PM
Red Light District Amp Screen Reg mach1 Tubes / Valves 20 28th February 2007 09:37 PM
Blank screen when I click on the thumnails QSerraTico_Tico The Lounge 2 11th February 2005 09:50 PM
