Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Philips CD-104 Improving Reading of CDRs
Old 28th November 2017, 07:27 AM   #11
Mooly's Avatar
I'm pleased something was a solution for you.
It is very much a case of experimenting with different media and burn speeds and observing to see which gives the best RF as viewed on the scope.
Old 11th December 2017, 07:18 PM   #12
phildela is offline phildela  England
I have recently found that something other than the CDM1 setup is contributing to the poorer reading of CDRs. Out of three CDR-104s I have only one of them could read the CDR burnt at 4x without artifacts in the sound and interuptions (all three read the CDR burnt at 16x without issue). I got my scope out and perfectly adjusted the CDM1s on all three units but it made no difference to the two that had reading problems. I swapped the Servo board of the better 104 with the poorer one and the fault didn't move, nor did it with the power supply. The last board I swapped was the Decoder board and this surprisingly made the difference. I am not sure which component is causing CDRs to not read well but I'm going to try renewing the electrolytics and I'll post the results once that's done. If anyone knows what could be the culprit for these read errors please let me know.
Old 12th December 2017, 07:24 AM   #13
Mooly's Avatar
I wonder if the error correction could be different... hard to say without doing an in depth investigation. Or servo time constants maybe.
As we keep saying though, these players are not designed for CDR from the outset and so anything is a bonus. I'm not sure setting up using a CDR is a good idea in the long run because you are optimising the player for an imperfect medium, possibly at the expense of playing Red Book standard discs.
Old 4th January 2018, 11:08 AM   #14
PAM is offline PAM  Netherlands
PAM's Avatar
The focus of the laser can be adjusted by the trox under de CD-drive motor. See service manual. Normal and CDR do have a different behavior / reflection for the focus. The bearing is wearing and sometimes you must set the table a little bit higher to a ready on your multimeter of 0 mV.
Working for people, music for gods
Old 13th January 2018, 05:42 AM   #15
Jonssen is offline Jonssen  United Kingdom
I've plenty of players with CDM1 that have had no 'tuning' and they will all read CD-Rs, even poor ones. Most read errors come from poor media and poor recording. Choosing decent quality (e.g. Taiyo Yuden) discs and recording on a decent drive (even at high speed) will produce a disc that reads without CU (uncorrectable) errors and negligable C2 (correctable) errors. Try a CD-R/CD-RW drive rather than a combo and use decent recording software. (There's a complete art to this if you can be bothered!) There's a list of the better audio recording drives on the web somewhere - Plextors generally work well. Certain drives will allow access to low level error data so you can use Plextools or similar to scan CDs and CD-Rs and see exactly what's going on.
Old 13th January 2018, 06:57 AM   #16
Keruskerfuerst is offline Keruskerfuerst  Germany
Keruskerfuerst's Avatar
The reflexions of an CD-R is much lower compared to a commerical CD.
This is the main reason why CD-R donīt work on old CD drives.
Old 14th January 2018, 02:39 AM   #17
Sorry, you are mis-informed
Old 14th January 2018, 02:54 AM   #18
Hearinspace is offline Hearinspace  Canada
Is there any chance that using different writer hardware or software would help a little?
Old 14th January 2018, 06:29 AM   #19
The laser unit could be replaced.
Old 16th January 2018, 03:52 AM   #20
Whatever for? The o/p didn't say it was faulty.
Philips CD-104 Improving Reading of CDRsHide this!Advertise here!
Philips CD960 - not reading disc - error yuetk Digital Source 3 18th July 2016 03:17 PM
Improving PSU of my old Philips CD371 ads2 Power Supplies 26 11th October 2014 02:45 PM
Aura AUC-50 (Philips CDM-9) CD reading problem ceharden Digital Source 3 16th April 2009 08:29 PM
Philips CDP reading fix... Tubeee Digital Source 6 21st March 2004 08:32 AM
Problems reading CDRs on NEC602 meat Digital Source 3 25th February 2004 08:52 PM
