Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Mod for Oppo DV-980H: direct output from CS4361 DAC
Old 2nd December 2017, 01:18 AM   #11
Andersonix is offline Andersonix  Sweden
Andersonix's Avatar
It's Friday happy hour, so could you point me in the right direction?
Old 2nd December 2017, 02:00 AM   #12
anatech is offline anatech  Canada
anatech's Avatar
Hi Andersonix,
Show me the datasheet that recommends running the DAC straight to the outside world. Please.
-Chris
"Just because you can, doesn't mean you should" my Wife
Old 2nd December 2017, 03:12 AM   #13
Andersonix's Avatar
The schematic in the OP is a screen capture of the Cirrus CS4361 datasheet Fig 6 "Recommended connection diagram" on page 11.
Old 2nd December 2017, 01:05 PM   #14
anatech's Avatar
Hi Andersonix,
Thanks, found it.
Did you include the output network, and have you looked at the loading on the output? I would think that their concern over loading internally would go (at least) double for direct connection to the outside world! There are a few op amps that have lower distortion and noise than the DAC has. Properly implemented, they would very likely improve the sound quality.
One thing I find striking is the lack of a reconstruction filter. They say it has been implemented on the chip, but I would want to check this anyhow. At -94 dB S/N, there are a lot of op amps that would suite this chip and provide the ability to properly drive cable reactance and the following input stage. Often times an output buffer will improve the performance of the output circuit in the D/A by unloading it. Without such a buffer, the performance would certainly depend on the load, including cables. You can expect the high frequencies to suffer first, and this may actually be why you prefer that configuration.
-Chris
Old 5th December 2017, 12:29 AM   #15
Andersonix's Avatar
Yes I added the two resistors and two caps as shown in the diagram, but no I haven't checked anything.
Old 5th December 2017, 04:56 AM   #16
anatech's Avatar
Hi Andersonix,
Check best that you can. It would be interesting to see how much of a voltage drop there was when you connect this to the preamp. If you have a test CD with a constant tone, it would be easy to check. You would want to use either an AC voltmeter (not a DVM unless it was like an HP 34401A or equivalent), or an oscilloscope. One of the newer digital ones might be better in this case.
Best, Chris
Mod for Oppo DV-980H: direct output from CS4361 DACHide this!Advertise here!
OPPO DV-980h msj965 Digital Source 2 7th September 2017 05:09 PM
Need Help on Oppo 980h display light msj965 Digital Source 0 6th March 2013 06:10 PM
OPPO 93 and OPPO 95 - A warning. sandyK Digital Source 3 26th January 2012 06:53 AM
OPPO DV-980H Service Manual volturnofelix Digital Source 2 14th November 2009 09:21 PM
Oppo DV-981HD output impedance vizion Digital Source 4 23rd May 2008 11:23 AM
