Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Changing from Electrolytic to Film Cap's
Old 7th November 2017, 10:39 PM   #1
pjf610 is offline pjf610
Default Changing from Electrolytic to Film Cap's
Hi All, Question, I read about changing electrolytic caps to film caps what is the reason for this and is their any advantages to it?? Example In my Marantz 2216B there are 50v1uf electro. caps and i was told you can change them to the same value in a film cap, what is the advantage to this ??
Pat
Old 8th November 2017, 12:59 AM   #2
Old'n'Cranky is offline Old'n'Cranky  Australia
First one must look at WHERE in the circuit they are.
Case by case basis.
Old 8th November 2017, 01:54 AM   #3
dotneck335 is offline dotneck335  United States
Lower ESR. Lower distortion.
Old 8th November 2017, 04:16 AM   #4
abraxalito is offline abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
With a film cap you don't need to worry about having correct polarization.
'The total potential here must be nothing less than astronomical.'
'Nothing less. The number 10 raised almost literally to the power of infinity.'
Old 8th November 2017, 05:44 AM   #5
georgehifi is offline georgehifi  Australia
georgehifi's Avatar
Send a message via MSN to georgehifi
If they are output coupling caps, yes it will be better with good quality plastics, just get ones that are 50v as higher voltage the bigger they are the worse they get, but still better than electro's
Cheers George
Avatar : Production Lightspeed Attenuator
www.lightspeedattenuator.com
Old 8th November 2017, 09:30 AM   #6
DF96 is offline DF96  England
Electrolytics are slightly nonlinear - although in most cases this won't matter if the cap has an appropriate value. They are slightly lossy - which the circuit may rely on.
Film caps are more linear, but usually physically much larger so sometimes there can be problems with stray capacitance.
So as others have said, it all depends on exactly how the cap is being used. Sometimes the swap can be an improvement, sometimes it will cause problems and much of the time there will be no change at all.
Changing from Electrolytic to Film Cap'sHide this!Advertise here!
Non-Polar Electrolytic vs. Polypropylene Film Capacitors gtforme00 Parts 30 1st August 2015 11:03 AM
Electrolytic Cap can I replace with film patfont Solid State 19 22nd June 2014 07:48 PM
Polarized Electrolytic vs. Polypropylene Film Capacitors pbtoko Parts 4 5th March 2014 01:11 PM
Electrolytic vs. Film 2A3 Cathode Bypass? batsong Tubes / Valves 4 6th July 2013 09:01 PM
film vs. electrolytic metebalci Parts 9 6th August 2004 11:44 AM
