Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Sony CDP 591 recognizes disc but doesn't play
Old 8th November 2017, 05:19 PM   #41
Mooly's Avatar
Could there be more solder blobs ?
You have to be realistic... all the processing is done within the IC's with very little discrete circuitry, and we know the original man made fault must have been fairly catastrophic to pop the two supply fuses. Now you have found a blob of solder that was causing an issue
The excess current to pop those fuses must have gone somewhere, and if it was into any of the LSI chips then its not looking hopeful I'm afraid. I think you are down to this either being caused by more inadvertent shorts (blobs) or some of the silicon is zapped.
Old 8th November 2017, 06:09 PM   #42
Depaj is offline Depaj  France
Unfortunately I checked really well and didn't see anything else. But could this little short between mute and reset have done all that damage ? This seems to be the only thing that I can see that I did wrong to begin with.
Would it be doable to try and replace these 2 IC's 301 and 302 ans see what happens or is the risk of getting fake replacements too high ?
Old 8th November 2017, 07:16 PM   #43
Mooly's Avatar
I wouldn't have thought a short on any data lines would do that damage, its more what caused the fuses to pop and where all that current went.
Faults like this become a little non logical as it is all uncharted territory I'm afraid, a little like repairing lightning damaged equipment.
Not much of fakes for parts like this but is it worth it ?
Old 8th November 2017, 07:51 PM   #44
Then it's probably something in the power supply that was about to pop anyway and just did it at that particular moment. I discharged the caps before touching anything, and there were no shorts anywhere else than the one I found today.
I'm finding that out the hard way. I don't know if the player itself is worth it but I don't really like to throw things away .
Old 23rd November 2017, 03:53 PM   #45
Well I got lucky and found a player that was ready to be scrapped (the laser was missing, tray mechanism was completely shot and front was bashed in). I started by swapping just the main board, and that took care of the "no sound problem" but the damn thing still didn't want to come out of mute so went ahead and swapped the front board as well and now it works perfectly. I think I will put those other boards aside and get back to them later.
Anyway, thank you Mooly for the help (again )
Old 23rd November 2017, 06:57 PM   #46
Mooly's Avatar
Pleased to hear you managed to get a working player out of it all at the end of the day.
Sounds like something did zap the logic somewhere as you found both boards had issues.
Sony CDP 591 recognizes disc but doesn't playHide this!Advertise here!
Why doesn't someone make a modern analog optical disc format for audio? MaximRecoil Analogue Source 47 24th December 2015 03:28 AM
casette player doesn't play Badsearcher Analogue Source 8 16th October 2013 10:12 AM
My sub doesn't play when connected to the stereo. pikipupiba Car Audio 8 10th August 2011 04:39 AM
can a vent which doesn't support sine play music? freddi Multi-Way 3 13th June 2010 06:11 AM
CD Player doesn't detect disc sometimes Gartak Digital Source 4 3rd January 2004 11:58 AM
