Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Sony CDP 591 recognizes disc but doesn't play
Old 4th November 2017, 10:07 PM   #21
Depaj is offline Depaj  France
Originally Posted by Mooly View Post
Q203 is the main +5 volt series pass transistor. If there is 5 volts on the collector then its probably OK. The scope should show a clean 5 volts with minimal noise and ripple (<50 mv pk/pk)
Sorry, my bad, Q203 is ok, it's Q202 that is gone. The ripple I see on the scope is about 30mv pk/pk. The +7v is clean as well according to those standards.
All I can do now is replace Q202 and go again from there. Should I try to get a 2SD774 or is there something more common that I can replace it with ? I won't be able to check if I get a signal before I restore the -5v rail.
Originally Posted by kevinkr View Post
If you touched up components in the servos (assuming they are analog) or pick up related electronics you may need to clean off flux residue.
I didn't touch anything on the servo board.
Old 5th November 2017, 07:05 AM   #22
Mooly's Avatar
Pretty much anything suitably rated should be OK for the pass transistor. Try a BD131 or TIP41. Make sure you get the pinouts correct.
Old 5th November 2017, 11:24 AM   #23
Ok got the -5v supply back and the cd is still reading but I don't get any sound (the hum is gone as well). The voltages on IC306 are good but I have just a lot of noise on the inputs.
The +10v rail drops to about 8.6v when the disc is spinning.
Old 5th November 2017, 11:49 AM   #24
Mooly's Avatar
The output IC306 should have full level audio, which is not necessarily present on the inputs.
Old 5th November 2017, 11:52 AM   #25
I'm only getting noise, whether the disc is playing or not doesn't make a difference.
Old 5th November 2017, 01:32 PM   #26
D208 and D209 are shorted which puts pin 1 of Q341,342 and 343 at 0v instead of 5.2v and also pulled the 10v rail down to ground through R209 explaining the 1.4v drop.
D209 is a 1ss120, can I just replace this with a regular 1N4148 ? And D208 is a RD5.6ES zener, I guess a regular 500mW 5.6v zener will do here.
Old 5th November 2017, 01:48 PM   #27
Mooly's Avatar
D209 is shown as a IN4148
Old 5th November 2017, 01:53 PM   #28
Those schematics look way better than the ones I have, on mine I had to go and look the part number up in the parts list and there it was stated as a 1SS120. May I ask where you got those ?
Old 5th November 2017, 01:56 PM   #29
Mooly's Avatar
HiFi Engine. Its free to register
Sony CDP-591 - Manual - Stereo Compact Disc Player - HiFi Engine
Old 5th November 2017, 02:35 PM   #30
Yes I know that's where I get all my manuals from, but mine doesn't look like that...
Oh wait, I opened it with microsoft edge, with acrobat reader it is waaaay better !!
I will replace the 2 diode tuesday and report back
Sony CDP 591 recognizes disc but doesn't playHide this!Advertise here!
Why doesn't someone make a modern analog optical disc format for audio? MaximRecoil Analogue Source 47 24th December 2015 03:28 AM
casette player doesn't play Badsearcher Analogue Source 8 16th October 2013 10:12 AM
My sub doesn't play when connected to the stereo. pikipupiba Car Audio 8 10th August 2011 04:39 AM
can a vent which doesn't support sine play music? freddi Multi-Way 3 13th June 2010 06:11 AM
CD Player doesn't detect disc sometimes Gartak Digital Source 4 3rd January 2004 11:58 AM
