Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
'90 jvc xl-z574: often "00" TOC displayed
Old 15th October 2017, 08:13 PM   #31
Mooly's Avatar
I find solder braid the best for removing parts. They should come out in seconds with zero damage to both print and the old parts.
The four 1.5uF caps in your diagram above all seem to be extra decoupling across larger electrolytics. If those are the ones you mean then ceramics are a good choice.
Old 15th October 2017, 09:01 PM   #32
seppstefano is offline seppstefano  Italy
seppstefano's Avatar
So it's time to buy some solder braid, I must say I never loved much the (de)soldering pump. Yes. the 1.5uF caps are extra decoupling near the DAC, in parallel to (moderately) larger electrolytics. I already beefed the elco up, with higher voltage ratings but was wondering if it might be the case to improve them: on the 1541 I seem I recall the general consensus was to exchange the ceramics with MKP or CDE polymeric.
Thank you as usual for sharing your time!
Old 16th October 2017, 08:27 AM   #33
Mooly's Avatar
Cheap ceramic caps really can be the best option for adding across larger electrolytics. Their low self inductance means they keep working well at the higher frequencies (filtering all the noise and hash generated by the DAC). I would leave the originals alone.
'90 jvc xl-z574: often "00" TOC displayedHide this!Advertise here!
Delivery Source for the 10cm "HR Vocal Driver" from "4722" LENS (47-lab) wanted tiefbassuebertr Full Range 1 5th September 2014 10:17 AM
The ubiquitous 1/2"...um....3/4"...er 1" ?? polycarbonate "dome" tweeter River757 Multi-Way 16 8th July 2013 01:45 AM
"WTB" "The Wire AMP" Class A/AB Power Amplifier based on the LME49830 with Lateral enantra Swap Meet 3 23rd December 2012 07:36 PM
3-way with big (10") woofer and monitor (6.5"+1") on top like "Tarkus" proxii Multi-Way 16 30th October 2012 01:43 PM
What makes an amplifier "bright", "warm", or "neutral"? JohnS Solid State 51 13th December 2009 07:42 PM
Copyright ©1999-2017 diyAudio
