| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#81 |
Thank you very much Dragon Master for that pinout ,
is 3,6 V and 7,6 V all ,no other voltages ? This was the answer i needed , a normal PSU is much easier that i thought ! Greetings from Germany Jürgen |
#82 |
Nope, nothing else.
Here's the text description: 1: 7.6v (Thru power switch) 2: Ground 3: 3.6v (Thru power switch) 4: Ground 5: 3.6v (Always on) 6: Ground 7: 3.6v (Reset sw / thru pwr switch, resets when switch disconnected) The only thing I'm not sure about is that 2 pins of a 4-pin IC are connected between the reset switch and reset pin(7). Maybe it changes something when the switch is pressed or not. Anyways, the voltage measured at the pin was 0 when reset is pushed and 3.6 if not. I am not able to read the markings on the IC. I guess a 12vAC transformer with two LM317 should work. I don't know if 1.5A is enough as the PSX with the current PSU uses 17w. Maybe LM150 or LM138 would be safer in this case. Mine measured 7.7v and 3.7v but a lot of sites with PlayStation info state that the voltages from the PSU are 3.6v and 7.6v. Mick, do you know the use of the trimmer on the current PSU?
Antoine http://dmsaudio.ca/ |
#83 | |
#84 |
I used my ps2 as a cd player for awhile. The low output actually worked well with my homebuilt preamp and kept it from saturating. However, now that I've fixed the preamp gain prob, the PS2 fan is too noisy for my tastes.
-Wes
Anything worth doing is worth doing right... and redoing to make it better... and again to fix it back the way it was. |
#85 |
hi i have a scph 5502 and the psu conector have only 5 cables.
#86 | ||
Here's the pinout: 1. 7.6v 2. GND 3. 3.6v 4. GND 5. Reset (3.6v when not pushed/ no more current when off) They removed the pins 4/5 of the 7-pin version and pins 6/7 are replacing them.
#87 |
thanks dragonmaster.
i was thinking to use an ATX psu from an old pc but i am not sure because it is switching. do you guys think i should do it or i should build a clasic one from scratch? |
#88 |
The current PSU is switching so I don't think there's a problem here. Anyways, SMPS PSUs are noisy so I don't think an ATX would be much better. Build a classic one. It's cleaner, simpler, and doesn't whine like normal SMPSes.
#89 |
Well I stripped the PSone down, to clean it, check for hack-chips and genreally feel my way around. Mick_F's photos are fantastic BUT larger than life - those components are so small !. Removing the DC caps would definitely be a one-way street, I doub't I could get the caps back on having removed them.
Maybe I'll defer to the huge body of German knowledge on this subject, where they don't appear to modify the actual board |
#90 |
thanks again i will build a new one
| Playstation CD Player | Beau | Digital Source | 2 | 19th March 2004 07:59 PM |
| Page generated in 0.12423 seconds (80.85% PHP - 19.15% MySQL) with 11 queries |
