Playstation as CD-player - Page 54 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 3rd January 2006, 03:14 PM   #531
Dommi is offline Dommi  Germany
Hi Mick,
i looked on your HP and i think there is a failure. If you disconnect the conducting paths like you've done there is a connection between the red RCA and the little component which suums the signal to mono. It not helps to disolver the caps upside.
I think it's better to disconnect the line shown on the picture below because we don't know what this little think makes with the Signal
BR Dommi
Old 3rd January 2006, 04:11 PM   #532
Hi @ all,
i measured the distance from cd clamp to motor. You have to press with a finger to the cd clamp and than the distance is
1,0 mm. This i measured on a new laserunit. Now i have to measure my other Units
Dommi
Old 3rd January 2006, 05:09 PM   #533
pieroh is offline pieroh  Germany
Originally posted by Dommi
Hi @ all,
Dommi
Hi Dommi,
this might be the solution for the problem!
I received a new laserunit with a scratching spindel and although I managed to raise it , it would not work properly.
If the distance between the CD and the Laser is different, erverbody will arrive at a different conclusion.
Anybody who tries to raise the spindel should be carefull not to break it. You can lift it with ease by inserting a narrow piece of metall, between the motor and the spindel and then gently pressing it backwards.
Peter
Old 3rd January 2006, 06:56 PM   #534
Mick_F is offline Mick_F  Germany
Hi Mick,
BR Dommi
Dommi, I have taken account of that. Instead of scratching the trace on the bottom, I found it easier to remove the little cap on the top of the board (see pictures 4.3 and 4.4
on my site . If you remove that cap, the RCA is completely disconnected from the circuit.
Mick
No statement here.
Old 3rd January 2006, 07:06 PM   #535
Dommi, isnt there something like a defined stop when you push the clamp onto the motor axis? I think there is, and then the geometrical distance between the CD and laser can be reproducibly fixed. We should find a set of alignment parameters for this distance.
It is just a guess, but judging from the findings of most of the users here (including myself) that the set 11.4mV / 1.7V / 1.8xV works very well, we may conclude that they all had their clamps in this defined position.
What do you think?
Mick
No statement here.
Old 3rd January 2006, 08:49 PM   #536
My last answer, of course, refers to the post of Pieroh.......
Sorry
Mick
No statement here.
Old 3rd January 2006, 09:16 PM   #537
@Mick:
5502 sounds more like a cheap CD-playa in comparison to a 1002.
Your cap-mod is exactly what Iīve in mind. This way 5502 and 1002 have the same output stage and can be jugded in direct comparison.
Just one hint: Twist or drill the wires, this way theyīll work as a a shielded cable. MKS is no good in audio, YEMV.
BTW: A23 recommended the line-out too. Maybe itīs system-dependent, you might need the extra drive in your setup. The opamp is a silly low power one, better to omit it.
Good to hear, that the reset isnīt needed.
The subject of the clamp distance needs more attention. There isnīt something like a defined stop when you push the clamp.
Anybody with a service-manual out there?
Carsten
Old 3rd January 2006, 10:22 PM   #538
back is offline back  Greece
Originally posted by carawu
@Mick:
Carsten
you tested them after the modifications?
Old 3rd January 2006, 10:39 PM   #539
No, I tested them before modifications. I had to buy some caps to do the mods.
Carsten
Old 4th January 2006, 06:09 AM   #540
jives11 is offline jives11  United Kingdom
jives11's Avatar
I noticed on the farnell website (www.farnell.com) that they have in stock surface mount 15uF /10v OSCON caps, plus a few other values
These might fit as replacements either side of the DAC, assuming anyone can solder SMT (rather than desolder )
Playstation CD Player Beau Digital Source 2 19th March 2004 07:59 PM
Copyright Đ1999-2017 diyAudio
