| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#41 |
For the PSU, it needs a multi-wire cable, but is it preferable if it has a shield?
Antoine http://dmsaudio.ca/ |
#42 | |
The one I use now has no shield and it works fine. Mick |
#43 |
I have read some posts which discuss providing an RF 'screen' around the PSU (assuming you leave it in the chasis).
Does anyone have a view on how enveloping of the PSU a screen would have to be ? Is a simple copper 'wall' between the PSU and laser assembly sufficient ? I have seen gear where brass or copper 'walls' seperate sections, but do not cover the sections. I found that an old copper RAM cooler (as used in PC overclocking) fits nicely between the clear plastic screen and the assembly. discard the clips and put the two sides facing you the same way, overlapped You need to be careful, but the plastic screen supports the copper screen and also provides some insulation. I assume the clear plastic screen is to deflect heat in the PSone, or maybe deflect fuse shrapnel in case of a catastrophic fuse failure You can overlap the two sides of the RAM cooler the same way and 'telescope' from the front to back of the grey box, under the supply cables from PSU to board. Difficult to explain, needs a diagram but imagine a 20mm high wall of 1mm copper from from to back along the divide between the PSU and laser. |
#44 |
yes, a shield made of any easy to bend metal (preferably a good conductor but most metals are good at this), and tie it to ground. That's it.
BUT : BE CAREFULL! it should not come anywhere near any voltages and certainly not the input AC!. Take a lid off of almost any digital component of quality and it will have a shield. If unsure or uncomfortable, please do not do this yourself, get a friendly tech friend or electrician to do it for you.
stew ☮ -"A sane man in an insane world appears insane." |
#45 |
But you still have the heat problem then!
Mick |
#46 |
RF noise, no thermal shielding... ok, make a 2 layer shield with a space to allow heat to convect from between them and vent the enclosure as well.
#47 |
But dont do this with the first version SMPS.....
No statement here. |
#48 |
why not? If heat is a problem and RF is as well, please explain to me why one couldn't do it? . I can rebox the thing (I have a 1001) in an Aluminium case from an old car amp, it will fit....and just use tha whole amp case as a shield and drill some holes in the top so that heat has someplace to convect to ....
Any further insight?
#49 |
I was referring to the different versions of SPMS used for the PS1. The very first versions came with a SMPS that dissipates quite a lot of heat. Later versions came with a Nichicon SMPS that dissipates 3W less of power. With the latter one you can try to leave it in the original place and maybe even shield it, but I wouldnt recommend to do so with the first version
Mick
#50 |
so the need to change the orientation or location of the the transport vs. the power supply, or remove the power supply completely from the same box , and shield it for rf?
| Playstation CD Player | Beau | Digital Source | 2 | 19th March 2004 07:59 PM |
| Page generated in 0.11695 seconds (75.13% PHP - 24.87% MySQL) with 11 queries |
