Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Playstation as CD-player
Old 22nd June 2013, 01:31 PM   #2861
dnic77 is offline dnic77  United Kingdom
thanks for the reply. ive used it without the resistors with the same results, i have put a 0.1ohm resistor on the capacitor and it sounds a lot better. im using both models 1002 and 5502 with the same mods and there both making the distorted sound.
Old 23rd June 2013, 01:01 PM   #2862
Pg2005 is offline Pg2005
Can you send some detailed pictures? 0.1ohm???? What is that for?
Old 25th June 2013, 11:28 AM   #2863
gavron04 is offline gavron04
Hi. I have problem with laser. The voltage is ok :
BIAS 1,70V DC
GAIN 1,80V DC
But... : http://www.youtube.com/watch?v=GG79m...ature=youtu.be
I have KSM440ACM
Old 25th June 2013, 02:41 PM   #2864
New link VIDEO00031] - YouTube
Old 25th June 2013, 11:08 PM   #2865
m4rk1z is offline m4rk1z
m4rk1z's Avatar
Hi!
I m new to this community and i wanted to share my modification with you as it sounds fantastic!
I m not using Mr. Manfred's output solution as i like to use the opamps, so
i tried the best opamps but i ended up using discrete dual's.
If you want to go that route them you must make an external power supply with +/- 12, 15, 18 or more voltage for the opamps only.
I m using big paper in oil and silver in oil capacitors before and after the opamps!
I hope this shematic will help someone
I compared my PS1 with Meridian Karan Shanling AudioAlchemy Asus Xonar Phillips Unison and other dac/cd players and you can guess what sounded best to ME
Greetings from Serbia.
Old 26th June 2013, 05:44 AM   #2866
Laser works good. Here is my moded PSX
Click the image to open in full size. Click the image to open in full size.
And others photos PSX jako CD - strona 2 - DIY - Audiostereo.pl - strona 2
Old 26th June 2013, 08:14 AM   #2867
very nice work !!!!
Is your laser working now?
Old 26th June 2013, 05:30 PM   #2869
Asioc is offline Asioc  Portugal
Ok, Now I can assure you that Mick's Mod is a GREAT MOD for my setup! Thanks Mick!
I've been using for years one 5502 with RCA females connected to the multiAV pins of the motherboard's back, and the sound was not bad for sure!
This month I got a second 5502 and it was time to do the final mod to the output stage, i've done some research and found that Mick's mod is simple (I like simple audio paths) and makes sense...
My amp is a Primaluna Prologue 2 with an input impedance of 65kOhm, and Mick's solution is giving me: 16,4kOhm Total impedance / 2,93Hz Cutoff frequency
I've used:
2x Wima 3,3uF 50v capacitors
2x 22kOhm 1% 600mW resistors
Solid copper wire twisted twin from cat5/6 cable (shielded wire gives sound coloration...)
Compared to my multiAV mod it's now evident that Mick's Mod is giving me some big improvements:
- a wider and well defined soundstage;
- better instruments separation;
- better dynamic
Old 10th July 2013, 08:34 AM   #2870
ctantra is offline ctantra
Originally Posted by danDman View Post
I tried Mick's mod replacing the output stage. And now the music is all distorted in the high frequencies, no bass, and the volume is very low. I'm using 3.3 uF caps at 50V (Wifa. Same as Mick) and 22 Ohm resistors at 4W. Is the wattage on the resistors to high? In the step by step instructions by Mich, he doesn't show were to cut the third connection to the RCA. May it be that I've missed the third cut? Does someone know were that might be? Please help.
I think you should use 22K Ohm, not the 22 Ohm.
Playstation as CD-playerHide this!Advertise here!
Playstation CD Player Beau Digital Source 2 19th March 2004 07:59 PM
