Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Playstation as CD-player
Old 24th May 2013, 07:33 PM   #2841
pixelphoto is offline pixelphoto  United States
Question about PS-1 (1001) sound. I have modified two PS-1's. In each I modified the output stage (Re dog breath mods) useing Elna Silmic 2 caps and Neotech hook up wire and silver bearing solder. I also recapped the PS with Nichicon caps Both have 300-500 hrs of use. I'm happy with the sound. BUT, they don't sound ANALOG anymore. Could the caps or the hook up wire be the cause?
Marvin
Old 24th May 2013, 08:08 PM   #2842
Cochise is offline Cochise  Germany
Cochise's Avatar
A silly question from me:
Why 4 x soldering with silver solder on a board with 1,000 Points without silver?
But our grandfathers have already said that elektrolytic capacitors do not purely belong to the signal path, no matter how good they are.
Here are a few pictures of my latest development EVO VI.
Vorführungen - Tet-Computerspezials
Supra-Bilder - Tet-Computerspezials
Cochise Audio
Greetings Cochise
Old 25th May 2013, 10:39 PM   #2843
Nanook is offline Nanook  Canada
Nanook's Avatar
Default Hookup wire affecting sound?
Marvin,
Over the years I have found that different conductor materials, dielectrics, and geometries (as in single strand solid core, multi-strand, etc) have a profound effect on the sound. Silver conductors can sound very "fast" (although they aren't fast, but they seem to get out of the way and perturb the electric field less), as does Teflon dielectric. Try some regular stranded (small gauge) copper wire and compare (you have two that are identically wired so a comparison would be easy).
I think you may find that copper sounds more "analog" compared to silver. This is just an observation though. I know there are plenty who would digress. The same can be said of solid core vs. stranded wire.
My favourite wire is a very cheap and good wire, sometimes sold at RadioShack: 30 gauge stranded silver plated Kynar. A pretty good compromise, it sounds "quick" and clean, yet retains the copper characteristics. About $10 per 100'. I've used it in tonearms, interconnects and signal carrying internal wiring in diy projects. I have never felt the want to change.
stew -"A sane man in an insane world appears insane."
Let's help Ruth and Dave
Old 25th May 2013, 11:14 PM   #2844
Cochise's Avatar
in silver solder is only 4% Silver's in it, why can there be better?????
apart from the problems of whiskers.
For all my work, I take French copper, for tonearms, i take it in 0.14 mm²
Edellitze für Audio 0,5 qmm, Cu-Feinstlitze, bestes Kupfer, sehr flexibel, RoHS | eBay
Greeteings Cochise
Old 25th May 2013, 11:21 PM   #2845
Nanook, thank you for your response. I was just thinking that very thought about the wire. I'll make the switch tomorrow and compare. Not being that experienced I really appreciate input from more knowledgeable diyers. Thanks again.
Marvin
Old 26th May 2013, 01:26 AM   #2846
Nanook's Avatar
Default wire?
pixel: no probs
Cochise: 0.14 mm² is between 25 AWG and 26 AWG, so we agree on the basic dimensions (I suggested 30 AWG, but 28, or 26 would be OK as well. 30 AWG is what I've used, that's all)
Old 26th May 2013, 01:51 AM   #2847
Cochise's Avatar
Hi Nanook,
the less mass I have, the less there are inductions.
Therefore, I use defined thin cable with a large surface area.
0.14 mm ² / 2 x 72 x 0.05 see picture.
26 Ohm / 1 Km
Greetings Cochise
Old 26th May 2013, 07:33 AM   #2848
Nanook's Avatar
well all you are doing is using small twin conductor. (If I am understanding you correctly). And your math?
Old 26th May 2013, 11:05 PM   #2849
Pg2005 is offline Pg2005
NEW´s from Mr. Manfred
he has a new external power PSU with Sony Design for his Playstation 1.
A detailed sound description will be developed shortly.
Neuigkeiten / News Playstation 1 SCPH-1002 High End CD Player deutschermanfred.de
File Type: jpg Externes Netzteil - Playstation 1 - SCPH1002.jpg (360.2 KB, 504 views)
File Type: jpg Externes Netzteil - Playstation 1 - Innenansicht.jpg (515.5 KB, 498 views)
Old 11th June 2013, 09:20 PM   #2850
gavron04 is offline gavron04
Hi. I have one question. How I can disable the startup sound ?
Playstation as CD-playerHide this!Advertise here!
Playstation CD Player Beau Digital Source 2 19th March 2004 08:59 PM
