Playstation as CD-player - Page 284 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 9th May 2013, 07:52 AM   #2831
@danDman
Unsolder at first the resistor and try again. Can you upload some pictures?
What scph version have you got?
Old 9th May 2013, 08:21 AM   #2832
Originally Posted by Norrovagen View Post
I am using passive preamp Sonus Qualitas pvvm1. I modded a SCHP-5552 today and made a bypass as described by Mick Feuerbacher. I am using 10uF capacistors and 4,02Kohm resistors. I believed that the caps would eliminate the DC from the AKM, but nope. I have tested with a buffered preamp with decouplers and that sounds good. What must I do?
I went yesterday to DIY heaven in Stockholm ELFA and bought F&T bipolar 100uF, 100Volt capacitors and 100kOhm resistors. I replaced the installed 10uF MKP caps and the 4,02 resistors. I used a buffered preamp to test the initial solution and it worked ok but efter the modification to bipolar caps and 100kOhm resistors it was possible to connect the schp-5552 to my passive preamp. I am using a inner tube from a wheel cart to isolate the PS1 from vibrations. Now the soundstage is detailed and has a lot of depth.
Old 9th May 2013, 01:15 PM   #2833
Originally Posted by Pg2005 View Post
@danDman
Thank you for such quick reply. I unsoldered the resistors and now it works fine! I have scph 1002. So should I get a resistor with lower values and try again, or should I just leave it as it is, with no connection to the ground signal? The picture is from before I disconnected the resistors.
Old 9th May 2013, 01:25 PM   #2834
Unfortunately there is still up to + - 6mV DC coming through. Can someone explain how I can get rid of it? I am using a ground isolator now until I understand how to fully eliminate DC from the output.
Old 10th May 2013, 08:15 AM   #2835
The resistor is only to filter low frequences. You don´t need a resistor if you want to listen what is on your CD.
by the way, why did you do the feuerbacher solution? Have you got a tube amplifier? The Playstation has now 0.8Volt´s output in you solution. Otherwise it is not necessary.
I have really nice results with just swapping the smd resistors. Output eff
have a look here: 21er - 22er - 23er Board 1,7Veff. Output Playstation 1 SCPH-1002 High End CD Player deutschermanfred.de
just swap the 18K OHM resistors to 27 - 28 K Ohm´s.
How do you measure? And what did you do?
you need a CD with an 1000Hz Sound (play it) and measure AC (not DC) at the RCA output to ground.
Old 10th May 2013, 09:08 AM   #2836
Thank you for your answer. This is my first test and I decided to try with a 5552 unit and the Feurbacher solution. I have 2 units of schp-1002 that is waiting. I normally play with my old Thorens TD126 or FLAC through the Logitech Transporter but could not resist trying after a friend brought a Playstation with him and gave me a big surprise.
Last night I realized that DC escaped to ground through the resistor so I removed it.
I swapped to old ERO MKC1860-5280 caps with 6,8uF. I have an input with 715ohm on the passive preamp and it gives me a cut off frequency of 3,2Hz. The passive preamp is followed by a 2x8 DSP with 30k Ohm. It now works and sounds very nice. Why should I measure AC on the RCA output?
Old 10th May 2013, 11:40 AM   #2837
I just wanted to know how you measure the DC, because there is only AC at the RCA output.
Old 12th May 2013, 06:41 PM   #2838
@Pg2005
Ok, no need for a resistor then.
Feuerbachers solution was just the first one that came up when i was looking for a mod, and yes, I was planning on using it for my tube amp.
I will look into that. Thanks for all your help Manfred!
Old 12th May 2013, 07:37 PM   #2839
@danDman
Hello, I am not Manfred, but he is a good friend of mine. We discussed the resistor a couple of days ago, that's why I knew what happened to you.
You said you have got a Tube Amp, so Mick's solution is perfekt for tubed amp's. Some tube amp's doesen't like to much incoming power.
Old 15th May 2013, 01:04 AM   #2840
Cochise is offline Cochise  Germany
Cochise's Avatar
Hello,
our new website,
it is available soon in English.
Cochise Audio
Greetings Cochise
Playstation CD Player Beau Digital Source 2 19th March 2004 07:59 PM
Copyright ©1999-2017 diyAudio
