| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#2721 |
Hi everyone, I am a noob here, but I was wondering if it would be possible to use a playstation as a DAC for a computer, using a USB/optical connection and perhaps wiring it in so that it bypasses the the processor or the laser input to the processor? (Just for your information, my knowledge of electronics is highly limited - as in I know what happens when you put resistors/capacitors in series or parallel)
#2722 |
Someone else will probably put me right, but I don't think that the player supports i2s which is what would be needed to supply a digital interface for a signal to a Dac.
#2723 | |
#2724 |
See, I told you I was wrong!
![]() There is a dig out mod for the Dreamcast that uses CS8406. Looks quite easy, if you like that sort of thing. Rob. |
#2725 |
emuman100: Wow thanks enuman! So that site gives circuitry for a TOSlink output right? So for a TOSlink input, would I wire in a switch to provide only the 5V power supply to the DAC (bypassing the unneeded components, but still allowing the possibility of use of the Playstation as a CD Player), and put the TOSlink connection into the input of the DAC rather than the output, and use the RCA/AV multi out? I found the schematic of the AK4309AV DAC (the one in the SCPH100x) on dogbreath.de (here), but my attempts at deciphering it were futile, haha! So if I decipher the schematic of the DAC, and work out the pins that take the input, and then wire the TOSlink connector from uyouyo.com in, it should work?
puffin: Haha! Thanks anyway Rob. Would the CS8406 sound better? I assume this is it? Thanks again to you both, and if I am making no sense at all, I apologies in advance ![]() Alex |
#2726 |
AK4310VM datasheet of interest to anyone?
My SCPH-1001 (that I've had since day 1 of US launch) has a AK4310VM. Seen the 4309B datasheet on here but not this one or a link to this one... |
#2727 |
Hello ,
i run a Playstation SCPH5502 on the two TDA1541A in old SONY CDP227-ESD (with damaged KSS 151 Laser) : SONY PS 1 SCPH5502 on parallel TDA1541A in a Sony CDP227-ESD - YouTube Conect the GND/LRCK/DATA/BCK and MLCK (16,9344MHz) direct from the PS to the DF CXD1144P . Lift up the MUTE Pins (4&5). It sound verx good . The DF works now in 4xOS mode . By Bernd
#2728 | ||
Attached is the original schematic designed by oscar, a Japanese fellow who figured out the video D/A converter inside the Gamecube D-Terminal and component video cable can output RGB as well as YPrPb, and this meant that when certain games were booted in 480p mode, you can display the game on a VGA monitor. I build the circuit in the schematic and it works beautifully. Last edited by emuman100; 5th June 2012 at 07:23 AM. |
#2729 |
I suppose if you are taking a dig out, you would be best to use a later version of the CS Digital Audio Receiver (CS8416)?
#2730 | ||
Could I just find a S/PDIF to I2S circuit (maybe using the CS8416 Puffin suggested), going into a AK4309 (or could I possibly have several in parallel?), then going straight to RCA out? or would I need to put the through something first? The Playstation mod uses this, but I read you can just use transformers and you get a better signal? I'm guessing the post DAC stage amplifies the signal? What would I need in terms of power supply? Quote:
Also, I found a DAC using the TDA1541 and the CS8416 on pavouk.org, here. Could I use something like this except use AK4309's instead? There was also just circuitry for the S/PDIF to I2S stage, here. Last edited by atomcf; 5th June 2012 at 01:12 PM. |
| Playstation CD Player | Beau | Digital Source | 2 | 19th March 2004 07:59 PM |
