| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#2391 |
Hi, thanks for the reply,
Please why do the need to be regulated?. I thought one of the good pionts about battery supply is that it gives a constant DC voltage. I do not regulate the battery to my T amp, it is just connected to the 12 volt tags on the battery. Cheers
tabarddn |
#2392 |
Hi
The ps1 needs a stable supply Voltage,when the battery drains the Voltage drops. With T- amp you don't need stable Voltage, it can be for example 10V-14V or something like that... One thing I tried some time ago was to feed the DAC chip directly with D-cell batteries ,unregulated.Just few diodes to drop the voltage close to 5V.
xxx I should correct my spelling xxx |
#2393 |
I recently finished my new enclosure for the PS1. It now fits very good to my lowboard. Like a chameleon
Perhaps a new power supply would bring some improvement... |
#2394 | |
Thanx! |
#2395 |
#2396 | |
Very nice and minimalist. Classy
Damn... why didn't I think of that! |
#2397 |
#2398 |
#2399 |
Hi
enclosed are the measures. The case is made out of 0.2" MDF for ground plate and frame. The top is made out of 0.5" MDF. The circle is made out of transparent acryl (PMMA). The veneer is french walnut. The coating is done with Danish oil. Pictures from the inside are momentarily hard to made because of time issues. The original PS1 top is omitted. The rest is mounted on the ground plate that is fixed with alu angles. I can make some more pics of the top and the back if you like. It was much work! |
#2400 |
WOW, you had me fooled.
I thought it was made from a solid block of wood excellent veneering
| Currently Active Users Viewing This Thread: 2 (1 members and 1 guests) | |
| karelch |
| Playstation CD Player | Beau | Digital Source | 2 | 19th March 2004 08:59 PM |
| Page generated in 0.10943 seconds (66.32% PHP - 33.68% MySQL) with 11 queries |
