Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 25th October 2009, 10:57 PM   #2381
karlton is offline karlton  United States
I just found a 9001 my boys had long forgotten about. Luckily they had a converter cord that went to RCA. I must say I am very impressed with it. Never would have thought I would be using a PS 1 as a CD player. Anybody else using a 9001?
Old 26th October 2009, 01:32 PM   #2382
Hi karlton
You have a "wrong" model,check this site : SCPH-1002 :: playfidelity
There are significant differences in the sound between different models,if you like the sound of the one you have now it's ok.
Long time ago I had nothing but possibly scph-9002?,at the time I didn't play much music though and to be honest it didn't sound good at all.It was then replaced with the cheapest Sony cd player at the time,and the improvement was huge.
xxx I should correct my spelling xxx
Old 26th October 2009, 02:25 PM   #2383
Tolu is offline Tolu  Germany
Tolu's Avatar
Originally Posted by carcass View Post
I've joined all the "grounds" together, is this a good practice in this case?
I would prefer a PS PCB that fits in the PS1 enclosure (5cm x 17cm or 2" x 7").
But I don't expect too much improvement in sound quality.
Old 26th October 2009, 02:31 PM   #2384
Default To Karlton
Yes it is only the US model #1001 that is believed to be good enough to bother with. However some of the later PS1's do have a superior transport/laser. Can't remember what the model # is for them. The model #'s can be confusing since they are different for US, Europe, Asia, etc.
Old 26th October 2009, 08:19 PM   #2385
carcass is offline carcass  Portugal
Well, the 1001/2 and the 5000 models share the same DAC, so modding the output stage will have the same results.
Using another newer transport will require some modding also to fit!
To Tolu,
I could try to design one to fit on the PS case, but keep in mind that Mick strongly suggested that it should be outside!
Regarding the grounds again, do you think I can use a ground plane for all of the circuit, or at least for the rectifiers part (msr860) I shouldn't use the same, or abandon completely the idea and return to separate signals?
Old 4th November 2009, 04:44 AM   #2386
msj965 is offline msj965  United States
Default spch 1001 for US
You can check it @ any used games stores,Craigslist. I bought mine on a garage sales last summer.you need to buy a remote control too, I got mine on a pawnshop near ur place.
Old 4th November 2009, 08:48 AM   #2387
I have been modifying PlayStation SCPH-1002 models by making the changes Mick suggested and connecting the DAC directly to the phono outputs via an R-C network (again according to Mick). I now have a batch of these machines, all cleaned and with adjusted lasers and with IR remote controls. I have been providing them to friends and family, but I am now advertising them on eBay for £50 plus postage. If anyone is interested please contact me. I can also make these mode to your machines if you like.
Old 5th November 2009, 12:42 PM   #2388
Tolu's Avatar
To Tolu,
Hi carcass
I don't know how hot the supply will get. But I don't think that the 10 or 15 Watt will be such a big issue. You can drill some additional holes in the top of the case. The rest of the PS1 is the more heat releasing part.
I am not the ground plane guru but I would divide the drive circuit from the audio circuit.
Old 5th November 2009, 02:39 PM   #2389
Thumbs up PS1 Run Off Of Battery Supplie
Can it be done? I have looked several times at Mike diagram of the upgraded P/S for the PS1. Quite frankly it is beyond my ability (and several others as well, if truth be know). But can the PS1 be run from a suitable battery supply that are set to the 7.6 and 3.6 voltages. Are these voltages mandatary or can there be a +/- to them without any harmfull or for that matter audiable affects.
Cheers and thanks for any replies
tabarddn
Old 5th November 2009, 09:25 PM   #2390
Hi
Battery supply is Ok but it really needs to be regulated and the battery must be relatively big,that means more or less the same type of circuit as you have seen at Mikes site,except the diode bridge and transformer.
It isn't really that difficult,if you put some time into it ,I believe you could make it.But there are still some safety issues even with the batteries(short circuit,fire).
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
bartgilchrist
Playstation CD Player Beau Digital Source 2 19th March 2004 08:59 PM
Page generated in 0.10404 seconds (68.49% PHP - 31.51% MySQL) with 11 queries
