Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 14th March 2008, 05:58 PM   #1881
Tolu is online now Tolu  Germany
Tolu's Avatar
Originally posted by dj_oatmeal
Tolu are you using the factory RCA outputs or the AV multi out? Unmodded the AV Multi out sounds very nice. I think you will have a different opinion if you try the AV output.
I will try it but the enclosed factory cables seems to be not of the highest quality.
What is the reason for this difference between RCA output and AV multi? What hearable effect can I expect?
Old 14th March 2008, 07:19 PM   #1882
AV multi misses out an opamp.
regards
willbewill
Old 14th March 2008, 10:24 PM   #1883
Tolu's Avatar
Thank you willbewill for that great hint!
I tried it right now. An improvement of about 90%!!!
It's shocking how much clearness and details have won. I am using the original cheap Sony cables with the multi A/V plug.
My modding has ended. There is not much to improve left I think. Any other mod can't give such a big improvement as with this method I think. I am very content an d happy now!!!
You're invited for a (german) beer (or two)!
Old 14th March 2008, 11:10 PM   #1884
Tolu:
Vpp means "Voltage Peak to Peak" and Vrms means "Voltage Root Mean Square".
The first should be obvious: it's the absolute value of the max amplitude from positive peak to negative peak of the waveform.
The second one is a kind of "average" value, only referring to one part of the waveform (the amplitude of one phase, for example from zero to positive peak), and taking an average value of that. Most AC voltages are measured in RMS, and in the audio domain, it's the preferred way to indicate voltage levels, besides the usual ways of of expressing them in dbV, for example...
If you want to get a "ball park" figure of conversion from Vpp to Vrms, do this:
Vrms = (0.5*Vpp) / 1.44
That DC-DC converter looks nice, though I think it's still the best to use a big linear power supply. With a switched DC-DC converter you always have some HF noise...
If you want, take a look at the link I gave a little back in this topic, from my PS Mod project, to get some additional ideas, as I've taken a slightly different way than Mick did...
Old 15th March 2008, 07:58 AM   #1885
Tolu's Avatar
Default Ánother problem
@joydivision: thanks for this good to understand reply.
After 3 hours of operation the laser of the PS had many 1-second-drop-outs so I had to finish my audio session.
What is the reason? A heat problem? The PS got remarkaby warm at the left side.
The power supply in an own box or a new one?
Modifying the bias values of the laser unit?
Any solutions? I was so surprised of the good sound so I want to keep the PS as my mayor player but it has to work properly and reliant. I hate trouble!
Old 15th March 2008, 08:08 AM   #1886
Probably the laser unit needs to have the bearing surfaces and the worm-gearing lubed with some lithium grease. It sounds like the laser may have trouble tracking the cd.
Old 15th March 2008, 09:22 AM   #1887
jives11 is offline jives11  Europe
jives11's Avatar
Lots of sudden activity in this thread I'm having trouble keeping up.
Nice neat and tidy job from vuthanh6. I like the style and placement of the buttons on the right hand side. Any chance of a picture of the inside ?
Originally posted by audio1st
Under test with an old PlayStation. Also gives you some idea of it's size..
That's an amazingly useful device, and extremely cheap it would seem. With a suitable 12v PSU of sufficient current you almost don't need any soldering at all.
I acquired an SCPH9002 last week, which has only an AV out . Listening via the adaptor cable it sounded pretty good. I curiously noticed that the remote's 'select' button does not seem to 'stop' with this unit, but other than that it worked fine. I fancy the treble was a bit rougher, but I did not listen for very long.
Old 15th March 2008, 10:48 AM   #1888
Tolu's Avatar
Thank you for that great hint! Read above my opinion about it!
Sorry, but I forgot you in my invitation for the beers!
Any other comment for my laser-drop-out-problem?
Old 15th March 2008, 10:58 AM   #1889
Probably not much help but I use the later 9002 laser units in 1002, the seem to be more robust and not too much modification is needed to fit them.
regards
willbewill
Old 15th March 2008, 07:22 PM   #1890
My first SCPH1001, I eventually had to replace the laser and motor with one from a PSOne. It reads everything now. But I still lubed the gearing.
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
karelch
Playstation CD Player Beau Digital Source 2 19th March 2004 08:59 PM
Page generated in 0.12089 seconds (60.16% PHP - 39.84% MySQL) with 11 queries
