| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#1661 |
I like the look of it as well. Are you willing to share any details of what you did?
#1662 |
Hi Audio
Must say the industrial "powerstation" look reminds me of Mr Tent's open board CD player. I see yours is a 5502 or similar. I have just been painting playstations and keeping the mods inside. Your idea has opened a new avenue maybe with a few LEDs could be made to look dramatic and maybe improving WAF. I have also got a PSONE case top and maybe will sink it into a top panel so that the area around the laser assembly is clean and neat. fill in the buttons like on that stealth PS1.The PSONE top panel looks good without a lid and might work well if you want to run without a top. It has better aesthetics than the greystations when topless. Also I see you can get 3rd party PSONE cases in the UK in tranparent colours. Its so nice to see people thinking outside the playstation box as it were ! Regards AnthonyPT http://www.edirectory.co.uk/pf/880/m...es/pid/4075942 (for PSONE cases) http://www.edirectory.co.uk/pf/880/d...mt/c/rid/10517 http://www.consoleplus.co.uk/index.p...on-psone-other (Mostly PSX cases but may have PSONE) http://www.interesting-devices.com/a...rchFor=&PT_ID= (for PS1 cases) |
#1663 |
Hi everyone, may I be so bold as to interject? Having a PS1 SCPH 1001 and no electronic / diy skills I saw an advertisement to have it modified here in Canada for $250. My question is will these mods make a real difference or is there something else you would suggest? The ad reads as follows...
Stage "One" PlayStation Mods available at Audio Oasis for $250.00CAD The purpose of our modifications to Sony's PlayStation is improve clarity, focus and detail while preserving the musicality and rich tonal balance inherent in the stock set up. We feel we've more than succeeded in these goals through a clever, compact,and somewhat unique series of modifications that result in a stock looking machine, with no outboard gizmo's or fragile interfaces, that performs way beyond the normal expectations for such a unit. We start by dramatically improving both the quality and quantity of capacitors within the digital power supplies to greatly improve the regulation and high frequency noise rejection of these sections. The parts chosen have ultra low impedance and superb high frequency performance resulting in a much more refined sonic presentation over the standard parts used. The values have been chosen to optimize performance at any particular point within the circuit. An area of improvement often overlooked is that of power supply decoupling of the DAC itself. The recommendations of the manufacturers are often ignored at this point in favor of economics. Here we have used a similar series of "super" electrolytic capacitor, (as mentioned above), to more effectively decouple the power supplies at this very critical point in the circuit. The basic analogue circuit topology used is that of complete minimalism, All bits and pieces between the DAC and output RCA are carefully removed and replaced by a stereo pair of output caps and load resistors... that's it! The output capacitors are made especially for this machine. These "trick caps" are miniature, high performance polypropylene capacitors in which their entire structure and associated lead wires are mechanically damped with various constraining layers and electrically shielded with copper foil. Our unique construction allow these superior sounding capacitors to live within the electrically and mechanically noisy environment of the machine with no ill sonic effects. To get the most from our finished machine the laser assembly settings must be optimized for best sonic performance these we have determined through careful listening tests and experimentation. Other enhancements can be made to our system but would not offer the same bang for the buck as those of our stage "One" mod. These might include: - further mechanical and electrical damping / shielding (feet, structure, repackaging, circuit board, isolation, etc...) - light injection into CD (green, blue, etc...) - "crazy ***" power supplies (can involve external dohickeys) - connectors - power cords and fuses - remote control Some or all of things can be done but we feel that, with the exception of the remote control, they would cost more than the benefits justify. |
#1664 |
Anthony
Thanks for links, I'll give the transparent cases a go. IMHO the 5552 sounds the same as the 1002 so those cases will fit OK. I usually keep all the mods in the case but I thought I'd try some big caps this time and that's how it evolved. I will make an original case model next with a separate external box for the caps and rca's. Attached picture of one of my 1002.. |
#1665 |
Wow ,
audio1st - fantastic design. Somehow reminds me of the Voight-Com test machine from "blade runner" diydummy - pretty much all of this work is described in this thread. the only thing alluded to is the DAC decoupling caps, which AFAIK no-one has changed, mainly because these are tiny surface mount cans. Easy to get off, less easy to resolder, but I'd guess they are referring to SM OSCON caps which are available. AnthonyPT - thanks for the links - I ordered myself a transparent blue case to go with the remote I have. I also just spotted this device http://www.interesting-devices.com/a...rchFor=&PT_ID= for the money , might be useful for parties where you want 15 hours of music on one CD |
#1666 |
Audio1st - Just wanted to 2nd what others here have said about your PS1. It looks stunning, and very similar to what I'd like to do with mine (if I had the tools and resources!). I was inspired by the 47labs CD player - similar looks.
Bet it sounds fantastic? Excellent work ![]() - John |
#1667 | |
I'll hold off paying to have it modified until I get a chance to hear what the player sounds like in it's stock form once my new amp and speakers arrive. John. |
#1668 |
if a schp100x,
I am no expert anything, and even I have managed to follow along..
stew ☮ -"A sane man in an insane world appears insane." |
#1669 |
Hi John
If you keep your money and fit isolation feet and a heavy breadboard base or similar as described in a few places on this thread then use the AV cable to start with, you will I hope be surprised how articulate the 1001/2 and the 5501/2 PS1 units are. Personally I like metal screws with wafer heads metric 10gx16mm. Then to get a good seating for all 4 feet I put a small square of cork with adhesive on top of the breadboard/ isolation board with eggshell foam underneath. Its an easy start. Just takes removing and putting back all screws. Video yourself as you go and you cannot go too far wrong. Good luck. Try and test out the player with a CD and CDR if you can. Try tracks at start middle and end of cd. Any friend with a multimeter, bluetack and electronic interest should be able to follow Mike_F's clear instruction if you do not feel up to it yourself. Regards AnthonyPT |
#1670 |
Johnm. I have modded 3 PS1's and built the linear PS for it as well. After 40 years into hifi I am gobsmacked at how good they are.
If you dont want to open it up and you want to send me your PS1 I'll mod it for free (or a bottle of wine !) What model is it ? |
| Playstation CD Player | Beau | Digital Source | 2 | 19th March 2004 07:59 PM |
