Playstation as CD-player - Page 156 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 17th August 2007, 08:06 AM   #1551
Great Minds eh puffin!
For the 4 ~ 5 each that the mundorfs cost me (shop on ebay) I certainly reccomend, especially if you are looking to put your caps on the outside.
Dan
Old 17th August 2007, 09:10 AM   #1552
Puffin is offline Puffin  United Kingdom
Dan. Where did you get your I.R receiver and how much was it ?
Is is Philips code ? How have you fitted it at the moment ?
Old 17th August 2007, 09:32 AM   #1553
I/R receiver came free with a game I bought for my PS2, never thought I would use it, but it certainly came in handy!
It is the same as the one which Mick uses only in a translucent case.
At the moment it is just plugged into the controller port
Ebay item 280143471679 is the same one - different brand though, no suprise there though.
Not to sure of which I/R code it uses, I may try a little experimenting this weekend.
Old 17th August 2007, 05:38 PM   #1554
Dan. I bid for a PS2 I.R receiver and remote on ebay and won it for 99p plus postage. I am reliably informed by my son that the ports are the same on the PS1 & 2.
Old 17th August 2007, 06:00 PM   #1555
Yep mine is for a PS2 as well so im sure you will have no trouble there
Old 18th August 2007, 04:40 PM   #1556
Send a message via ICQ to AnthonyPT
Hi
Just finished painting my latest PS1 with
a BAM Laser assembly installed. So
far this one sounds the best and I must get
to sorting out the power supply away from
the player. Player is very articulate and runs at
11.4mv.
However I have another 1002 player that I do not
seem to be able to sort out. The laser is 11.4mv
and idle bias 1.7v Laser hunts so I wonder if
the gain is really way out. Any ideas of getting it
into a range where it will read CDs even easy to
read ones. I have worked on 11 PS1's and this is the
first to not respond to adjustment even with a laser
change from a bad ACM to a better ACM! Also came across
a Ir remote that gets confused with Sharp code. Will
post more details. Best Remote for me is my Futuretronics
which will read Joytech Ir sensors better than Joytech
hand remotes. The Joytech remote reads Futuretronic Ir
Sensors better than it reads its own Joytech Ir Sensor!
Must back up the code! Really enjoy this thread.
AnthonyPT
Old 21st August 2007, 07:56 AM   #1557
decided to have a break from trying to squeeze the last drop of hum from my system last night, so moved onto the playstation:
I added the remote into the case and also added some spikes.
The spikes are from oregondv.com and offer good value for money IMHO.
As a note, I would say putting the remote in the case is a bit more fiddly than the output mods but less chance of damaging something important with static.
Did anyone else who did this mod manage to keep the overall metal screen in place, I can't see it on Micks site and it really didnt seem like it wanted to go back on (kept all the other screens on though)
I reccomened this to everyone though, it makes the PS look a lot more 'finished' I'm really coming to like the Playstation case as well - I reccomend a quick buff using UniPol plastic polish to bring it back to a fresh grey finish.
Dan
Old 21st August 2007, 08:08 AM   #1558
Mick_F is offline Mick_F  Germany
Nice work, Dan. Afaik you are the first to follow the suggestion to include the RC receiver into the case. As you say, it makes quite a difference optically.
I have put all the shields back into place. The overall shield sits a little tight put it still fits in.
Now, next give your PS1 a low-frequency damping base. You can follow the instructions on my page. This makes quite a difference sonically.
For trying this out, you can already hear the effect when you put the PS1 on a soft pillow. Listen to complex passages of a well recorded CD with and without the pillow ....
Mick
No statement here.
Old 21st August 2007, 09:17 PM   #1559
pieroh is offline pieroh  Germany
Default DC-powersupply
I made some experiments with a DC-powersupply today.
I use a 12V-battery and two LM317 voltage regulator boards to set the voltage to 7,6V and 8,5V.
Another transistor regulator (inspired by Mick!) with a TIP122 built into the PS, drops the voltage from 8,5V to 3,6V. The heatsick is far too small though, I will change this.
The audio signal is taken directly from the solder pads near the DAC and fed into two Russian military grade paper + oil caps (1F) with 1M-Ohm to ground. A tube line preamp is used for further amplification.
Man, it is heard to believe, this sounds like beeing on a life concert, very dynamic, tight bass, very soft upper frequency range.
Try it!
Piero
Old 22nd August 2007, 06:18 AM   #1560
Excellent work. If you turn the reg in the case by 180 you may be able to put a larger heat sink on it.
Where did you get those capacitors?
Mick
No statement here.
Playstation CD Player Beau Digital Source 2 19th March 2004 07:59 PM
Copyright 1999-2017 diyAudio
