Playstation as CD-player - Page 153 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 7th August 2007, 11:26 AM   #1521
Dommi is offline Dommi  Germany
Hi @all,
can we talk again about why you don`t use a battery supply instead or parallel to the analogue PSU ?
BR Dommi
Old 7th August 2007, 11:34 AM   #1522
Puffin is offline Puffin  United Kingdom
Dan. Thanks for that. I have a 1002 which I tried in stock form and thought it was rubbish. I then modded it by taking the signal out, straight off the pads by pins 15 & 16 and addings caps and resistors and new phono sockets. Wow what a difference. if the PSU takes it to another level again, then it is worth the outlay.
Old 7th August 2007, 12:34 PM   #1523
Mick_F is offline Mick_F  Germany
Yes it does. Try it
No statement here.
Old 7th August 2007, 09:52 PM   #1524
Default Battery Power
Hello Dommi
Yes i am very interrested in using battery power for PS1
since this is the purest power possible
I think after reading these 61 pages on this thread
There was very little information about it Infact the only info i found was that batt power is not suitable for PS1 Maybe i missed something
Now I believe a lot of people would like to now how you are doing it
How do you get the 7.6 and 3.6 volts required and how are you charging the batt
I visited your site and did not find info about it
By the way I purchased 2 more Ps and measured the laser
The values are like you explaned 1.46 to 1.48 for bias and around 1.80 for gain
Thanks for the info
Greetz and enjoy
Old 8th August 2007, 03:35 AM   #1525
Send a message via ICQ to AnthonyPT
Hi chips666,
Have thought about battery power with
regulators and decent amount of reserve
capacitance. Maybe a 12volt 7ah battery
would give a reasonable operating time
between charges.
I have recently installed a BAM (PSONE)
grey laser assembly. Did not have to tweak
it just had to modify the SCPH1002 case and it
seems very articulate and I like the sound.
Perhaps the BAM's history of running in the little
PSONe without having to deal with the power
supply in the same case may be an advantage.
Must move the power board outside the PS1
but for now have a copper dam between the
boards so not so much heat reaches the
laser assembly area. Either external power or get
on and convert the thing to run on the gel cell.
AnthonyPT
Old 8th August 2007, 04:06 AM   #1526
Scioneer's Avatar
Has any other console been tried? I found the Dreamcast isn't a bad cd player when I lived in my Apartment and had my Dreamcast doing double duty ( game console and CD Player for my stereo) to save space. It sounded better than my Optimus CD-7300 6 cd changer.
Old 8th August 2007, 07:46 AM   #1527
Default Re: Battery Power
Hi chips
it`s verry easy to use a battery for power supply. Take a 12 V minimum 7 AH lead akku. Use a simple voltageregulator like LM317 an regulate the 7,6 V power. With a second regulator on the output of the 7,6 V regulate the 3,2 V. With a 4 pole switch you can switch of the charger an switch on the PS1 and vice versa. I don`t had the time to discribe it on my homepage. But in a few weeks i think it will be there. I can switch between battery and norm pwr. with a relay. So i can make a direkt A/B comparison.The sound with battery supply is much better than ac supply. The music is much calmer than with ac power. With ac power sometimes the voice and the instruments seemed to move some centimeters. Now, with battery, there are still on the same place. And thanks for measurement of the laser powers. Do you have problems reading any kind of cd with this values ?
regards Dommi
Thanks for the info
Greetz and enjoy [/B]
Old 8th August 2007, 08:25 AM   #1528
Mick_F. I have been looking at the details of the Linear PSU on your site. I am not very good at reading schematics and I wonder if you can clarify the detials of the bridge rectifier.
On the two 7.6v boards you have 4 TO220's grouped together, they look like voltage regulators, but are they diodes ?
Old 8th August 2007, 08:31 AM   #1529
Puffin, I beleive those are the MSR860 diodes, however I couldn't easily get hold of any over here and so I went for the MULTICOMP
SB560 schotty instead (someone else tried several and this came out ontop) , available from farnell without newark extra duty (what a rip off!)
I'll get onto those pics as soon as possible.
Old 8th August 2007, 08:44 AM   #1530
Dan. Is it not acceptable to use say a Maplin bridge rectifier, or IN400X diodes ?
Playstation CD Player Beau Digital Source 2 19th March 2004 07:59 PM
Copyright 1999-2017 diyAudio
