Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Help Arcam CD73
Help Arcam CD73
Old 18th July 2017, 05:51 PM   #11
Mooly's Avatar
Help Arcam CD73
Good luck, and let us know how you get on if you have it fixed
Old 5th September 2017, 09:41 PM   #12
sattwa is offline sattwa  Italy
Just one more question.. aparently there should be a sensor somewhere to indicate the end of the end of the rail, could that be the cause of the fault?
Meantime motors for spinning the CD and moving the laser do not move anymore when i switch the player on and when insert a CD but the tray still opens and closes correctly
Old 6th September 2017, 08:19 AM   #13
Mooly's Avatar
Help Arcam CD73
There is normally only a single sensor (microswitch) for detecting the rest position (inner position) of the pickup, not one for the outer end.
Old 6th September 2017, 08:31 AM   #14
OK, so as you previousely said most probably the problem is not in the pick up block but in the electronics that drives it located in the pcb. I was hoping that changing the all mechanics (which should be quite easy) would solve the problem
Old 6th September 2017, 12:31 PM   #15
Mooly's Avatar
Help Arcam CD73
You really should check all the supplies as I think we mentioned earlier. The service manual will show them all.
Old 6th September 2017, 12:52 PM   #16
OK Mooly.. thank you again :-)
Help Arcam CD73Hide this!Advertise here!
Arcam cd73 Edwar65 Digital Source 6 26th September 2017 08:00 PM
Arcam cd73 Edwar65 Digital Source 0 28th December 2013 08:12 PM
arcam cd73 Edwar65 Digital Source 3 25th February 2013 11:18 AM
Arcam cd73 Edwar65 Digital Source 21 24th October 2012 09:29 AM
Marantz 6000 OSE vs Arcam CD73 miamiphoto Digital Source 0 27th October 2010 11:52 AM
Copyright ©1999-2017 diyAudio
