micromega optic bs - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 19th May 2017, 12:00 AM   #1
bolly is offline bolly  Canada
bolly's Avatar
Default micromega optic bs
purchased a supposedly working unit, with transport locks, it showed up and right off the bat it didn't look good. The locks were left in the holders and not inserted into the transport!
when I insert a disc the error led illuminates and no track list is shown, the disc does spin.
when I select a track and press play I can hear slight clicking sounds inside the machine, its a CDM-4/19
anybody have any ideas?
Old 19th May 2017, 06:59 PM   #2
bolly's Avatar
is there anything a guy can do with a few simple tools?
Old 19th May 2017, 08:55 PM   #3
bolly's Avatar
is finding another working player with the same transport and swapping it feasible?
Old 30th May 2017, 09:09 PM   #4
Did you open and inspect the unit? Optic/Digit is a fairly simple machine. Assuming that you were sent a working CD player, you should look for any obvious nicks and cracks, both inside and outside, loose or detached flat cables and connectors. Pay close attention to the laser mechanism: does the swing arm move freely, does the turntable rotate smoothly, is the flat cable healthy.
Then, with the lid open, try inserting a CD and observe how the transport behaves when you press PLAY. You should see the lens bobbing up searching for a reflective surface where it expects it to be, the swing arm should move to the initial groove and the disc should spin then for TOC readout. This is the initial sequence which you should confirm happening. I think that getting another working player at this moment is too early because the fault may be simple and easy to fix, before you end up with two identical and working ones.
Old 30th May 2017, 09:20 PM   #5
bolly's Avatar
hi willi studer, yes it works exactly as you say, arm is free, lens goes up and down. I hoped it was a dead laser so I found another cdm4/19 and swapped it in and it still says error, will not read toc
Old 30th May 2017, 09:40 PM   #6
As a general rule, never swap transports straightforwardly because you always risk killing the second transport, too, in case a deadly fault lies outside it. Your finding is actually good because it may indicate that the transport is actually fine. I would suggest closely inspecting the player for obvious mechanical/connection problems caused during transport. Does the disc spin up?
Old 30th May 2017, 09:45 PM   #7
bolly's Avatar
thank you willi studer, I'll have another close rlook at it, you gave me some good tips!
BS band pass Beat Street Subwoofers 15 5th December 2013 10:17 AM
Has anyone tried this BS correction circuit? G Full Range 4 14th January 2008 09:11 PM
Breakthrough...or BS? InclinedPlane Full Range 8 1st February 2007 11:49 AM
horn vs. BS hulkster62 Full Range 7 23rd December 2006 10:06 PM
Copyright 1999-2017 diyAudio
