Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 22nd March 2004, 06:57 PM   #1
WTS is offline WTS  Canada
Default DF1706 and software mode control?
Hi; I did a search for this but didn't find any info so I was wondering if anyone has done any work on the software mode control for the DF1706. I'm interested in the level control part of it and whats the best micro to use with it.
Walter
Old 22nd March 2004, 08:47 PM   #2
I recommend a PIC with EEPROM to store the volume setting in nonvoltile memory. Just make sure to pick one with SPI support and you probably can't go wrong.
Stu
Old 22nd March 2004, 10:02 PM   #3
Hi Stu, thanks for the reply, I'll take a look at the pic's. Whats the one you would suggest, micros are not my fortay. What kind of programmer do they require and is there software for writing the program and programing them.
Walter
Old 23rd March 2004, 12:57 PM   #4
macboy is offline macboy  Canada
PIC programmers are easy to build yourself. Do a web search for JDM programmer, and you'll find a lot of information. The complete IDE including editors, assemblers, and even simulators is available for free download from the manufacturer, Microchip. They also have a great library of application notes and sample code to help to get you started.
Old 23rd March 2004, 02:03 PM   #5
It really depends on the feaure you need, ie. number of I/Os, internal oscillators, A/D convertors etc. How many I/Os do you need?
Stu
Old 23rd March 2004, 04:51 PM   #6
Hi; Thanks for the replys guys. I'll do a search on the web for more info.
How many I/O's would it need? I'm not sure maybe 6/7 . 2 i/ps for the up/down switches and 3 o/ps for the serial data and maybe add a few extra for good measure I guess
Walter
Old 23rd March 2004, 05:30 PM   #7
HI; I do have some 8515's which where used for something else, but they are kinda big, 40pin, and are probably overkill for this. My big problem is getting the required data into the proper form to program it with.
Walter
Old 25th March 2004, 05:12 AM   #8
jwb is offline jwb  United States
jwb's Avatar
Send a message via AIM to jwb
If you already know how to program the 8515, I'd recommend the compatible and far smaller (but still DIP) ATmega8. The STK-500 is the best way to program them, and it's less than $100 from Digi-Key. I write my code in an editor, compile it with avra and load it onto the chip with uisp. There is probably equivalent software for Windows or MacOS, if you use those. You should also see http://www.avrfreaks.net/
Nice thing about the AVR is it's built-in SPI port. You don't need to worry about the protocol, it's handled in hardware. Makes banging data into the DIR1706 or the CS8420 a snap.
Old 25th March 2004, 10:02 PM   #9
Hi jwb; Thanks for the info. No I don't know how to program the 8515 either, but I'll learn somehow. I don't recall seeing in the 1706 specs anything about SPI interface?
Walter
current mode control classd4sure Class D 31 1st December 2011 05:50 PM
UC3846 current mode control vs. SG3525 with average current mode control mflorin Power Supplies 32 4th November 2009 04:43 PM
UC 3846 current mode control IC help jegandren Power Supplies 3 1st July 2008 04:41 PM
UC3847 current mode control IC doubt on Vref jegandren Power Supplies 2 29th February 2008 03:09 AM
Current Mode Control And Voltage Mode Control jegandren Power Supplies 4 26th February 2008 08:26 AM
Page generated in 0.10158 seconds (76.89% PHP - 23.11% MySQL) with 10 queries
