Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 22nd March 2004, 01:28 PM   #1
raveon is offline raveon  Denmark
Default Problems when burning CD's
Hi there
I wonder if anyone could give me some help with this problem:
I record from vinyl to hd with cooleditpro and the wav-files sounds okay, but when I burn them on to CD, the volume on playback everynow and then fades up an down.
I've had this problem before. Any suggestions? Is the cd-burner (Lite-On) just getting tired?
regards
/raveon
Old 25th March 2004, 12:37 AM   #2
Do you have problems with continual line voltage fluctuations? Try measuring voltage over a period of time - that might be the reason or do you have enough RAM to support what your doing ?
No matter what you should be running 512 Meg to burn something - are you getting a buffer over run statement?
Steve
Old 25th March 2004, 03:01 AM   #3
daschwa is offline daschwa  United States
Are you experiencing the volume fluctuations on the actual *.wav, on the computer before it is burnt to CD?
Old 25th March 2004, 01:50 PM   #4
Steve
As a matter of fact I don't really know.
But I've made another attempt. I thought that it was my phonoamp that had a fault, so I replaced it with a batterypowered one, and this time I close-listened during recording. Nothing wrong there. BUT when I listened to the recorded wav the problem was there.
So now I'm beginng to wonder if my on-board soundcard is bad. Is there a fault in the AD-conversion? There is no problem when I rip a cd and burn that (EAC). I'm having 1024 DDR and no signs of bufferunderrun.
regards
raveon
Old 25th March 2004, 01:51 PM   #5
Yes
raveon
Old 25th March 2004, 06:09 PM   #6
pburke is offline pburke  Germany
if the wav is bad, your audio extraction is flawed.
go to www.exactaudiocopy.de and grap the software there. Your drive should be recent enough to work well with this software.
you can also burn CD with EAC
Peter
Burning in GC, results and problems dw1narso Chip Amps 43 23rd November 2006 01:24 PM
Page generated in 0.07408 seconds (74.46% PHP - 25.54% MySQL) with 10 queries
