about SAA7310P - Page 2 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 19th March 2004, 11:16 PM   #11
Thanks@arniel.
I'm getting have an idea transplanting SMD-version saa7310 to my marantz CD99. But I'm afraid of other device is broken.
Other device means IR2339(compareter), MN4264P-15(RAM).
I broke these devices by adding 20V!!
So, it's more safer solution getting CD880(having very similer@devices to CD99) than getting CD50(has SAA7310 SMD version).
I don't know what happen when install SAA7310, and CD50 may be not have other necesary devices.
Old 19th March 2004, 11:38 PM   #12
Please don't take this the wrong way, but is it really worth the effort? Depending on where you inserted the current, chances are every IC on the mainboard is broken!
Old 20th March 2004, 12:40 AM   #13
Exactly!
But there is a little hope.
I added 20V to saa7310, compareter and DRAM, but not to other devices. CD99 has several boards, and I tried separate power supply between servo system and signal processing one.
I added high voltage to only one board.
But, of course, other boards connected by signal line, it is possible many other ICs damaged!!!!
Old 27th August 2004, 06:18 AM   #14
Default After that.....
Hello, everyone.
After that, I get marantz cd650, and it has SAA7310PB and DRAM.
So I transplanted SAA7310PB and DRAM to my cd99.
And I can repair my CD99.
By the way, comparetor is not damaged.
Thanks all.
Old 27th August 2004, 04:51 PM   #15
guido is offline guido  Netherlands
guido's Avatar
Default Re: After that.....
Originally posted by haitaku13gou
Hello, everyone.
Thanks all.
Mmm, a marantz 650, never heard of. Is it the philips 650 sold as marantz in japan??? If so, you should have found a 7210 in there (or a M4xxx chip). I think there are some small differences between 7210 and 7310, check the datasheets.
regards,
GuidoB
Old 27th August 2004, 06:22 PM   #16
Thanks for reply, guido.
I don't know phillips CD650.
But may be you right.
There are many marantz CDPs in Japan,
but they have phillips devices.
my marantz cd650 has devices like this,
CDM2
SAA7210P/A
SAA7220P/A
TDA1541
SAA7310 is a SMD version of SAA7210, isn't it?
I did mistake.
My CD650 has not SAA7310P/B, but SAA7210P/A.
My CD99 originaly had SAA7210P,
and I change this device to SAA7210P/B.
My original CD99 sometime has trouble when TOC reading,
but after change decorder/controler to SAA7210P/A,
my CD99 reads correctly TOC.
Old 27th August 2004, 10:56 PM   #17
guido's Avatar
CDM2
SAA7210P/A
SAA7220P/A
TDA1541
I did mistake.
Yep, that's a philips CD650, also sold as magnavox (got that one myself). 7310 is NOT 7210 in smd, it is a more advanced version of 7210. Differences can be found in the datasheets.
Dunno much of the differences between the P, P/A and P/B versions of 7210. Maybe that P/B is just broken...
Did you try it in the 650?
Congrats you got it working.
GuidoB
Old 28th August 2004, 06:09 AM   #18
Sorry, I did mistake moreover.
My CD99 has SAA7210P, and I change it to SAA7210P/"A" from
CD650.
So, I tryed it in CD99.
CD650 is just a donner.
CDM2 is in my junk box.
Sounds something different when TOC reading
between SAA7210P and SAA7210P/A.
SAA7210P/A sounds like read TOC again and again until success.
But SAA7210P gives up immediately.
Copyright ©1999-2017 diyAudio
