Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 16th March 2004, 07:52 AM   #1
pop11 is offline pop11  Canada
Wink Has anyone actually measured Elso's Asynchronous Reclocker?
I have seen posts arguing for and against Elso's Asynchronous Reclocker (or any other Asynchronous Reclockers), but I could not find any real measurement on its effect. For e.g. how it affect the jitter value, spectrum etc.
Personally, I have tried the Asynchronous Reclocker and found it to be a small improvement for my TDA1541A, but I don't have the means to measure it
Can some kind soul enlighten me on this?
Old 16th March 2004, 03:14 PM   #2
Pedja is offline Pedja  Serbia
Pop11,
Since you ask about the effects and since I have not measured the same DAC (TDA1541A) without the reclocker, this graph answers the question only partially, but it clearly shows that the asynchronous reclocking which uses the frequency which is not the multiple of Fs does not result in the low jitter, it certainly raises it.
For those not aware of, the thread with some info and some opinions about this issue is here:
http://www.diyaudio.com/forums/showt...390#post326390
Pedja
Old 17th March 2004, 06:56 AM   #3
Default thanks ...
Thanks Pedja,
Should there be a couple more plots overlays on the graph? so to compare the jitter before and after?
Old 17th March 2004, 08:45 AM   #4
Fabian is offline Fabian  Switzerland
Default some more measurements
hi pop11,
I did some basic measurement of four different TDA1543 based DACs. Two of them have no reclocking, one has Elso's reclocking and the last one has the reclocking circuit according to Doede's DDDAC1543.
The reclocked DACs sound better than the non-reclocked (IMHO) and both reclocker as well decrease the sonic influence of the transport.
But the reclocked DACs measure worse. Elso's reclocker adds alot of jitter, Doedes reclocker will drop or repeat a sample from time to time. Click on "measurements" on http://www.geocities.com/tdac1543/ to see some screenshots of my measuremts.
Fabian
Old 17th March 2004, 09:24 AM   #5
Exclamation I'm shocked!!!!!
Elso's reclocker has a jitter level of "10500ps" !!
but Elso's reclocker did improve the sound ... beats me ...
I wonder what will happen if we modify Elso's reclocker and bring the jitter back down to a lower value, it may be a killer!
Any idea how to reduce jitter in Elso's reclocker?
Old 17th March 2004, 02:09 PM   #6
Default Re: some more measurements
Originally posted by Fabian
hi pop11,
Fabian
Hi
Impressive setups and thanks for sharing measurements
While the jitter is indirectly measured, the outcome still is valid for indicative use.
In my research last years it has been often shown that certain types of oscillators sound very fine, but measure worse. In contrast, oscillators with very low jitter can be very revealing.
Similarly, some people prefer certain types of of (tube) amplifiers
In the end, it just depends on what you are looking for, soundwise, that is.
best regards,
Guido Tent
www.Tentlabs.com
Cheap Asynchronous USB jkeny Digital Line Level 5 26th September 2009 11:24 AM
Asynchronous reclocking Ulas Digital Source 62 24th January 2006 08:19 PM
Asynchronous reclocking problem Andypairo Digital Source 11 23rd December 2003 09:46 AM
Asynchronous Clocking weinstro Digital Source 0 12th June 2003 05:31 PM
Page generated in 0.08359 seconds (79.16% PHP - 20.84% MySQL) with 10 queries
