Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 15th March 2004, 01:54 AM   #1
Default Denon DCD1500
Just found one of these at a thrift store. I want to tinker with it. What should I do to modify it? I'm going to start with the power supply by recapping it. Can I upgrade the op amps and dacs? If I can what will work in it?
Thanks,
Ed
Old 15th March 2004, 06:12 AM   #2
Electrons are yellow and more is better!
peranders's Avatar
This CDP from 1986 (mine is that old but works still after so many hours at work) has small potentials to be tweaked. The major drawback is a 7-pole (or was it 5?) LC-filter in a tin can. In 1986 the CDP was realy cool with oversampling but times are different now. The CD has one good property: Can handle scratched CD's rather well becuase of the slow laser pickup.
/Per-Anders (my first name) or P-A as my friends call me
Old 15th March 2004, 06:50 AM   #3
Test Pilot's Avatar
Too bad it wasn`t a DCD-3560, that`s a killer-drive!
But the DCD-1500 shure can be improved too. Uppgrading trafos gives more than changing caps, start with analog-supply.
But the easiest way to uppgrade is to add a set of extra
RCA`plugs on the rear, localise the out-signal on the op-amp(s) and just run the signal from there(bypass).
Another simple uppgrade is to add a solid-core powercable.
Ok, that`s a good start
Old 16th March 2004, 01:49 AM   #4
Which pins on the chips are the outputs?
Ed
Old 16th March 2004, 07:46 AM   #5
Test Pilot's Avatar
That`s the funny part, if you don`t have a service-manual you just have to searc for them. I`ve used to do this with my system "playing", on low (!) volume, with a thin/soft little cable connected to the output you can take a "tour" inside your player searching for the best sound
Sounds scary? Just remember to do the ground-connection before you start searcing your op-amps!
Good luck!
PS.
Mybe you should write a letter to your family before doing this, just in case
Old 16th March 2004, 08:05 AM   #6
peranders's Avatar
Let the DCD-1500 rest in peace or have it at work or something.
Old 16th March 2004, 08:06 AM   #7
peranders's Avatar
Ed
I have the service manual if you are interested.
Old 18th March 2004, 03:08 AM   #8
Can you email the manual to me? edward897@yahoo.com
Ed
Old 20th March 2004, 06:16 PM   #9
hanyu is offline hanyu  China
can you email the manual to me plz?
ktvaudio@hotmail.com
thx a lot!
Old 24th March 2004, 03:02 AM   #10
KCC is offline KCC  Canada
Well,I have a DCD1400 that does not read the disks in one end of the house but works perfectly in the other end of the house.And this is not a one time affair.I've tried this many times.Soon as I relocated the player to any other rooms in my house it stop reading any disks. Soon as I brought it back to my work bench it works without problems. The electrical outlet in my work bench is next to the fuse box.I've upgraded the output stage for this player. Anyone experienced such problem before?
Denon PMA-560 sparkle Solid State 16 6th November 2010 06:07 PM
Need Help on Denon DCD-S10 Noak Digital Source 64 21st February 2009 11:45 PM
Denon PMA-655 elec972 Solid State 0 23rd November 2008 02:42 PM
Picture of DCD1500 inside Bernhard Digital Source 27 15th May 2006 01:53 AM
Denon Pma-860 ManUtd Solid State 4 11th January 2005 08:14 PM
Page generated in 0.09847 seconds (79.43% PHP - 20.57% MySQL) with 10 queries
