Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
need help with IIR filter
Old 13th March 2004, 12:47 AM   #1
theChris is offline theChris
Default need help with IIR filter
this is for a school project. I need to make an AA filter for resampling a file. i've done this with a FIR filter and using Matlab's default, and using an averaging filter, but i would like to add a IIR filter to the mix as well. i'm not sure my results were very good.
i made 2 matrixs with 11 elements each, for my coefficients.
then i made 2 matrixs 10 elements long to hold x(n) to x(n-9).
maybe i left off a term, i think there was supposed to be a x(n-10) as well.
the algorithm shifts in a value of x, then runs the equation summing the elements of a*x and b*y then placing then shifting the result into the y matrix.
am i anywhere near correct on this?
in anycase i don't really need the IIR to be correct, it's mainly to impress the teacher with our project. this isn't a DSP class, just communications. but i would like to get it working.
if only it could be used for good, not evil...
need help with IIR filterHide this!Advertise here!
need help wana change 60-Hz twin-T notch filter to 279 Hz filter prorms Solid State 0 9th February 2008 11:38 PM
Can Zaphs notch filter be used without the BSC filter? GuyPanico Full Range 0 21st July 2007 01:27 AM
Just one big filter cap or more smaller filter caps ... beppe61 Power Supplies 2 18th July 2006 05:46 PM
active filter from rod elliot and sub filter questions wuffer Parts 0 2nd October 2005 01:12 PM
chassis-mounted filter or IEC plug filter jarthel Solid State 7 11th March 2002 10:17 AM
Copyright ©1999-2017 diyAudio
