| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
If I were to build a HTPC, and use a Create Audigy 5.1 sound card, can I connect the outputs to a 5 channel amp, or do I still need a digital decoder?
#2 |
Yes, you can use the 5.1 channel analog outputs of the soundcard. With most cards, you would requireDVD playback software that has DD (and optionally dts) decoding capability. With the Audigy though, you can just tell the software to send the DD stream to the S/PDIF port, and then enable the setting int he Audigy drivers that tell it to decode the DD stream into 5.1 sound. One caveat: I do not know if the audigy decoding allows you to turn off or adjust the dynamic range compression. If not, then it will probably be on by default. That isn't necessarily bad (especially if you have small speakers) but you won't get the full impact of the soundtrack. Not all DVD software decoders will allow you to adjust this either.
Also be aware that the sound quality will not be great. The inside of a computer is an electically noisy place, and some of that noise invariably gets into the audio signals. Sending the DD data stream to an external decoder will probably provide significantly better results. |
#3 |
most of the decent motherborad nowadays have onboard spdif output, so you do not even need an extra soundcard. for example, in my pc i use the onboard spdif coaxial output going into my receiver, which decodes ac-3 and dts. this _is_ the best way to go, if you take analog signals from the pc you will invariably get noise. i use long runs in my room and i had about 75ft of cable (tons of hum). after building a balanced line driver it went down considerably however it wasnt perfect until i just used straight digital output -- used cheap radio shack 75ohm video cable and it works like a charm
go to newegg.com and browse the motherboards with the nvidia ultra-400 mcp-t chipsets, they have very very nice audio onboard. for example, this motherboard has onboard apu with spdif input and output coaxial, as well as optical toslink output -chris |
#4 |
The *best* solution IMHO is to get the 6 or 8 discrete channels digitally from the soundcard to external gear. This is easy with some (like the good old SBlive! that has 4 separate S/PDIF outputs on a header).
Some cards have I2S signals that can be tapped and sent outside... |
#5 |
Some related sites I have collected on the subject:
S/PDIF and 5.1 audio http://www.andrewkilpatrick.org/mind/spdif/ SB Live misc info http://w1.910.telia.com/~u91003452/l...live_start.htm SB Live Value to SB Live 5.1 conversion and lots of info http://users.andara.com/~cquigley/sb.html |
#6 |
this is not realy answering your question but if your building a htpc then have a look at www.mini-itx.com there some realy good boards.
#7 |
#8 | |
Just a thougth... :-) BAF |
#9 | |
Try this: plug the analog output (like headphone/speaker output) of the soundcard into your audio system. Turn the PC volume all the way down and click mute. Now, no audio should be produced by the PC. Turn up the volume on your audio system so that you can hear the background noise. Do some stuff like opening a large file (to cause disk access), access the network, etc. You will almost definitely hear a lot of garbage. If you switch your audio system to a CD player input and put the CD on pause, you will not hear as much background noise. |
#10 |
Another thought:
Check out the Creative DDTS-100 external decoder. It does DD, DTS, Neo-6, and a few others I believe and is meant to be used with powered PC-type speakers. Perhaps a neat DIY project would be to rip the thing apart (they only cost US$100 or so) and use it as the decoder section of a decent homebrew A/V switch, preamp, volume control, etc. using decent components. You end up with S/PDIF in and whatever-you-want out (e.g. se/differential, line level, etc.) Hey, you could even add your own bass management if you wanted...... The manufacturers won't sell the chips without licenses, but nothing says you can't buy one of these (or any A/V receiver) and hack it any way you want to suit your system...... Bill |
| Does it exist: Dolby Digital Decoder Chip Or Board? | 6f6 | Parts | 7 | 14th March 2007 11:05 PM |
| Dolby Decoder | hop_305 | Digital Source | 4 | 7th August 2004 11:34 PM |
| Dolby Digital / DTS decoder DIY link | nFORCE | Digital Source | 6 | 22nd September 2003 04:19 PM |
| Dolby Digital 5.1 amp for Sound Card | dracul | Everything Else | 3 | 29th August 2003 04:37 AM |
| Standalone Dolby Digital & DTS Decoder | Neopsp | Everything Else | 2 | 3rd May 2002 11:49 PM |
| Page generated in 0.11845 seconds (80.40% PHP - 19.60% MySQL) with 10 queries |
