Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Oppo new UDP series players - 203/205 - Discussions, upgrades, modifications
Old 22nd May 2018, 08:23 AM   #491
santodx5 is offline santodx5
Helo,
Does anyone know what 25mhz clock do? Which clock affect the HDMI? Is it 25mhz?
Thank you
Old 22nd May 2018, 01:28 PM   #492
Coris is offline Coris  Norway
Coris's Avatar
The 25M Mhz clock it run the optical drive decoder/processor, beside it.
The HDMI interfaces are part of the main processor, which is clocked by 27Mhz. In 205 model, HDMI audio dedicated output is processed by its own (SI) processor, clocked by a 27Mhz resonator, in addition of a SAW 148,5 Mhz oscillator.
Old 23rd May 2018, 06:02 PM   #493
JamieMcC is offline JamieMcC  United Kingdom
Hey guys I was wondering what opamp is used for the headphone out on the 205 as it sounds pretty good to my ears, any one know what it is?
Old 23rd May 2018, 07:13 PM   #494
Coris's Avatar
Indeed, the headphone output it sound very good in a stock device, as in a improved one as well.
The headphone section is enough complex. Many stages, and it have dedicated two of the DAC chip (paired) output channels tied together. First stage it use LM4562. Followed by a OP1632 stage (both fully differential stages). Then it follow a balanced to unbalanced conversion, using the TPA6120A2. In the end, the signal is outputted through a discrete buffer (power) stage.
Even though a so complex design (it was really necessary so many stages?), they could not prevent (or cared too much about) important oscillations which this stage it produce in 30 - 40Mhz range. TPA6120A2 chip is known for its instability, if special design measures are not taken into consideration. Well, Oppo designers had in mind a good (right) idea when they decided to use as feedback signal for TPA6120, the output of the final buffer. In this particular case, such (also right decision) it caused the whole stage to oscillate in Mhz range. These oscillations are of course not audible, but it is healthy, heaving it into a high quality device? I do not think so...
However, the stage it sounds great. In my opinion, this it is mainly because the buffered DC coupling output...
Old 23rd May 2018, 07:40 PM   #495
Coris thanks for your superb reply it is much appreciated.
Old 24th May 2018, 05:05 PM   #496
dtossan is offline dtossan  Canada
Hi Coris
Does your excellent LPM provide soft start?
Den
Old 24th May 2018, 09:55 PM   #497
Coris's Avatar
Hi Den,
Well, the power supplies (for digital stage) in Oppo devices are designed to be always on (connected to main power, and providing power at its output). The start of the device itself is controlled by its power management (software).
I provide soft start included in my DC blocking filters for important power applications (from 100w upwards), but in this case, for so low power (50w), it is really unnecessary...
Old 25th May 2018, 10:25 AM   #498
kevner1954 is offline kevner1954  United States
Don’t know where to really put this ,but I purchased a AIX SAMPLER BLUE RAY disc from them in California and it won’t play in my oppo 203 . I’m in Pa. on the screen the text comes up as a true HD and BD is there something I don’t have set up right on my stock 203? Is it a regional thing?
Old 25th May 2018, 10:27 AM   #499
It play as far as running ,but no sound
Oppo new UDP series players - 203/205 - Discussions, upgrades, modificationsHide this!Advertise here!
Oppo's BDP105 - discussions, upgrading, mods... Coris Digital Source 1799 15th May 2018 08:41 AM
Oppo BDT-101CI - discussions, improvements, mods Coris Digital Source 15 9th January 2018 09:29 AM
OPPO`s HA-1 Headphone amplifier - discussions, upgrading, mods... Coris Digital Line Level 168 16th November 2016 09:42 AM
OPPO BDP-105 with linear power supply and modifications eganz1 Swap Meet 0 30th October 2016 02:21 PM
Modifications to Sennheiser VKS 203 antiantiv Tubes / Valves 13 22nd November 2012 08:15 PM
