Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Oppo new UDP series players - 203/205 - Discussions, upgrades, modifications
Old 13th October 2017, 12:11 AM   #301
motospark is offline motospark  United States
Send a message via ICQ to motospark Send a message via AIM to motospark Send a message via MSN to motospark Send a message via Yahoo to motospark
Thumbs up Look like it belongs in there :)
Originally Posted by Coris View Post
Then trying so...
It looks very professional, like it belongs there.
Mark.
MAS
Old 13th October 2017, 01:10 AM   #302
Discopete is offline Discopete  Canada
Originally Posted by motospark View Post
Hi all, I wanted to share this with you all. I found a good cable to go from the headphone jack to RCA's. Found it on Amazon, here is the link.
Amazon.com: Hosa TRS-202 1/4 inch TRS to Dual RCA Insert Cable, 6.6 feet: Musical Instruments
I do agree Coris, out of the three outputs (Stock) the headphone sounds the best, though it does lack a little punch, but the increase in transparency and clarity especially in the upper frequencies is great.
Mark
I'm not a cable/wire guy but I would get Coris' take on the comparison. That patch-cord looks a bit thread-bare.
Old 13th October 2017, 11:32 AM   #303
tekko06 is offline tekko06  France
Mark.
I agree.
Old 16th October 2017, 03:11 AM   #304
Smile Update.
Well I'm at a cross road, I have all the parts I need to replace the existing output caps. I have two brands, Panasonics OSCONS SECP 470uf 16v from DigiKey and ELNA RFS Silmic IIs 470uf 16v from Parts Connexion, and the bypass caps Wima 1.0uf 62v polyester. I cannot fully bypass the Eletrolytics due to my Parasound Halo Integrated design, I have already decided that after speaking to the techs at Parasound.
Not sure which I'm gonna go with, I would like to use Polyprops as my bypass caps but i'm not sure what value to use and I know they run big and keeping the leads short is also a consideration. After reading a bit I learned that the best cap to bypass the Electrolytics is a Metalized Polypropylene because of how transparent they are compared to the other material, with Teflon being the most transparent.
I already have replaced my switching power supply of my 205 with a liner type.
Time to do some more research, I'm open to your thoughts and suggestions.
Thanks much in advance
Mark.
Update:
After reading many posts and material on Caps here and there I have decided to replace the Decoupling caps with the ELNA RFS Silmic IIs 470uf 16v (non-magnetic leads) tin coated copper.
I'm still looking for a film type bypass cap, one that will fit.
Moto.
MAS
Oppo new UDP series players - 203/205 - Discussions, upgrades, modificationsHide this!Advertise here!
Oppo's BDP105 - discussions, upgrading, mods... Coris Digital Source 1776 9th September 2017 09:55 PM
OPPO`s HA-1 Headphone amplifier - discussions, upgrading, mods... Coris Digital Line Level 168 16th November 2016 09:42 AM
OPPO BDP-105 with linear power supply and modifications eganz1 Swap Meet 0 30th October 2016 02:21 PM
Oppo BDT-101CI - discussions, improvements, mods Coris Digital Source 12 16th August 2016 12:52 PM
Modifications to Sennheiser VKS 203 antiantiv Tubes / Valves 13 22nd November 2012 08:15 PM
Copyright ©1999-2017 diyAudio
