Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 11th March 2004, 12:16 PM   #1
Default Slaving transport to DAC clock - with a wrinkle
Hi
I would like to implement a low-jitter clock in my DAC and slave my transport to the same clock
There seem to be two commercially available ways of doing this:
1. LCAudio - install a LClock XO 3 in the DAC (215 Euros). This has two clock outputs, one is used for the DAC, the other is taken by a user-installed co-ax lead to the transport and replaces the crystal in the transport
2. Guido Tent - XO-DAC with XO module in the DAC (267 euros), and a XO-3 with VCXO module in the transport (132 euros), with a link cable between the two. I don't really understand how this option works, but it does result in a free-running low-jitter clock in the DAC (ie not pulled about by a PLL anymore)
In any case, the whole thing is dependent on the transport and the DAC having the same clock frequency.
In my case, I have a Meridian 500 transport and an Audionote DAC kit 1.2, both are nominally 11.2896MHz
BUT....in this DAC, the 11.2896MHz clock is not actually used at all, instead a 2.8224MHz clock from the receiver chip is used to directly clock the DAC chip.
So in fact I would need a low-jitter 2.8224 clock in the DAC and a 11.2896MHz clock signal to send to the transport.
I do know that Guido's XO-DAC when fitted with a 11.2896MHz VCXO is capable of outputting the 2.8224 frequency, because this is what I used to use in my DAC until I blew the XO module up by being careless one day. I hope this is still possible with the XO module fitted, but I don't know.
Does anyone know whether the LCAudio LClock is also capable of outputting sub-multiples of the basic clock? (2.8224 = 11.2896/4)
Has anyone got experience of either of these two sync'ing methods?
Maxwell
Old 11th March 2004, 03:12 PM   #2
guido is offline guido  Netherlands
guido's Avatar
There is another recent post with all the info. I'm doing this for a 11.2896MHz CD player
too. In short: clock at DAC 11.2896 MHz with some dividers to get 2.8224MHz. And the
11.2896 is fed back to cd players decoder/filter. Inbetween you can put a fifo to avoid
timing problems, somebody did without however.
Use search on the word fifo.!
The other
GuidoB
Old 11th March 2004, 04:13 PM   #3
Default Re: Slaving transport to DAC clock - with a wrinkle
Maxwell
The 11MHZ clock in the DAC1.2 is not a standalone clock. It is intimately tied to LRCLK and SDATA. For this to work properly you would have to generate SCLK (11.2896MHz) and LRCLK (44.1KHz)
and send them to the input receiver and dac chip with the PLL based clock in the transport.
ray.
Old 12th March 2004, 05:38 AM   #4
Guido
A search on fifo brings up 56 threads, and I'm afraid I can't work out which one you're referring to. Can you give me another clue?
I'm not an electrical engineer, I'm really wondering if either of the commercial sync-link options (LCAudio or Tent) will work with my DAC.
Old 12th March 2004, 10:48 AM   #5
Default Re: Re: Slaving transport to DAC clock - with a wrinkle
ray.
That last line should have read
"send them to the input receiver and dac chip using a fixed clock in the DAC1.2 with the PLL based clock in the transport."
ray
Old 12th March 2004, 10:56 AM   #6
guido's Avatar
Guido
Buffer choice for IIS Direct
GuidoB
Old 12th March 2004, 09:40 PM   #7
Thankyou Guido, I appreciate the trouble
Clock frequency of CEC TL5100 transport lwaudio Digital Source 1 13th November 2011 06:55 PM
Philips Cd-Pro2 player/transport w/ tent labs XO3 clock - $1000 o.b.o. Julien_M Swap Meet 5 24th January 2009 11:03 PM
Slaving a transport to a DAC Dr.H Digital Source 2 13th March 2008 02:53 PM
Clock input to transport joeling39 Digital Source 5 25th January 2004 01:24 PM
clock feed to transport board question khush Digital Source 7 28th March 2002 04:39 AM
Page generated in 0.10474 seconds (79.57% PHP - 20.43% MySQL) with 10 queries
