Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 7th March 2004, 10:18 PM   #1
Send a message via Yahoo to mikelm
Default "super pair" I/V new 12.7V version
I just finnished building the cct below and am listening as I type
This version is designed for 12.7V battery operation.
At first is was not stable so I added the 1nF caps, I am not using a ground plane which might explain the need for them. -3dB about 100Khz
I have 10uF film caps on the board at present - I will try other values later.
The "Three diodes" are in fact red LEDs. I will try putting 1uf caps across these later. In simulation it seems to have a noticable effect.
This cct sounds really very good very detailed but also smooth a refined. The words natural and organic come to mind...
Many thanks to Rudolf and any others involved in the development of this cct
Old 8th March 2004, 04:54 AM   #2
sparkle's Avatar
Hi, I like it, I like it,......
What transistors did You use....? Did You use 2999R resistors or 3k? Kidding, just kidding!!!!! Nice job really...
daniel
Old 8th March 2004, 06:26 PM   #3
One thing that I did not mention is that in implementing this I took the oportunity to have a fairly ideal earthing scheme.
The only point where the two channels have a common earth is just by the DAC. All the other supplies and earths are separated for each channel
In theory this should help.....
mike
Old 8th March 2004, 08:07 PM   #4
sparkle's Avatar
... And the transistors?
daniel
Old 8th March 2004, 09:51 PM   #5
daniel
Well I used some faily high gain ( 400 - 500 ) that I had to hand.
If I where to buy new I would go for BC550C & BC560C or similar
mike
Old 9th March 2004, 04:50 AM   #6
sparkle's Avatar
Old 17th September 2004, 07:35 AM   #7
Andypairo's Avatar
Default Re: "super pair" I/V new 12.7V version
Hello Mike,
while looking for a suitable output stage for my new experimental TDA1545 dac I stumbled on your project, that would allow me to use battery power... but I need a few clarifications:
the vref input is the vref pin of the dac? I guess that such pin, on the DAC side, should be used as usual (or not?)
The V/I resistor is the 999 Ohm just before the output cap, if its value calculated for the 1543?
Andrea
Old 19th September 2004, 09:42 AM   #8
Default Re:"super pair" I/V new 12.7V version
Hi Andrea,
The Vref is fed into this cct and as you can see goes through two diode junctions one npn and one pnp - which means that, more or less, the same voltage is presented at the i/p from the DAC
I designed this cct for the 1545 and from memory I think that the same Vref is fed into the DAC aswell ( I can't find the manual at the moment ) The function of this is to allow the DAC drive into the voltage that it is most comfortable with. I think it will also work with the 1543
For best quality it is very important that the Vref is very clean so I would at least regulate this supply from the analogue battery or better still give it it's own battery. The Vref itself is can gained with two resistors with a cap across the o/p if the supply is clean. I think it has to be 2/3 of the supply voltage to the 1545.
If you have not tried alkaline non rechargable batteries yet you may be in for a pleasant suprise - only trouble is we then got to work out a way of replicating their sublime sound that avoids having to buy new batteries all the time.
The 1000 ohm resistor at the o/p is what finally converts the current to voltage and as such the value could be altered to suit your requirements. I used a non-inductive wire wound from RS for this resistor and the quality is excellent.
I would be very interested to hear how you get on with this
good luck
mike
Peavey "Super Festival" VTA-400 - upgrading to 400W? pharaohamps Tubes / Valves 11 22nd March 2009 12:25 PM
Wanted: KSA50 clone boards, "Jan" version wim Swap Meet 0 18th May 2007 07:18 AM
"Super-Pair" I/V for TDA1543 rbroer Digital Source 159 19th November 2004 01:11 AM
Audio Crafters Guild "Super Symmetric Power Supply" raincheck Digital Source 16 22nd April 2002 08:06 AM
Page generated in 0.10094 seconds (79.97% PHP - 20.03% MySQL) with 11 queries
