| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Just found your site-looks great, I'm a bit of a digital virgin, but I've had great success moding my TDA1451A equipped player. It's got a SRPP ECC88 output stage with battery negative grid bias, a first order passive filter and some PSU upgrades and sounds miles better than standard. I'm now looking to the next upgrade and wondered if anyone could advise me on the feasibility of bypassing the digital filter in the SAA7220. Obviously I'd need to do something about the clock but what else? Any wise thoughts would be appreciated. Simon: |
#2 |
Hi Simon,
Everything you need to bypase SAA7220 digital filter and put your cd player in nonoversampling filterlees mode of operation is here: www.xoomer.virgilio.it/hi_fi/com.htm - if you have SAA7210 or SAA7310 in DIL, connect pin 23 (SAA7220) to pin 11 (SAA7210/SAA7310) - if you have SAA7310 in QFP, connect pin 23 (SAA7220) to pin 18 (SAA7310) This will restore mute function. |
#3 |
Hi aparatusonitus,
Thanks for the reply, but the link you posted seems to be dead cheers, Simon |
#4 |
Oops found it now,
the mod looks pretty simple, so I might stand a chance! thanks |
#5 | |
Lyra |
#6 |
Try this one: www.xoomer.virgilio.it/hi_fi/index.htm
#7 |
It does't work... Just google the address a bit, then you have it, I hope.
#8 |
#9 |
Hi Simon
Is the DAC/Audio board in the 70.2 a single or double sided PCB?
Regards Fin |
#10 |
Hi Fin,
The Dac, clock, output stage and various power supplies are on a long double sided board across the back. There's no ground plane unlike the processing board, just traces. I'm interested in why your'e interested! Simon |
| Arcam Delta 290 | lduarte1973 | Solid State | 2 | 28th February 2009 09:06 AM |
| Arcam Delta 70/70.2 | FibCouple | Digital Source | 2 | 12th January 2008 11:42 PM |
| Delta 290 Arcam | mike salway | Solid State | 0 | 17th September 2005 03:03 PM |
| Arcam Delta 70.2 | Rotellian | Digital Source | 2 | 16th January 2004 10:33 PM |
| Page generated in 0.10527 seconds (81.15% PHP - 18.85% MySQL) with 11 queries |
