Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Rotel RCD855 no output
Old 3rd May 2016, 09:12 PM   #1
napovo is offline napovo  Canada
Default Rotel RCD855 no output
Hi all,
I am newbie here and I need your help. I've purchased a Rotel RCD855 from a museum sale. Plugged it on with a CD, the machine is reading the TOC. All the buttons functions work, but there is no sound from neither Analog or Digital output.
Can you help me to diagnose the problem and fix it please?
Thank you very much,
Napo
Old 4th May 2016, 06:46 AM   #2
percival007 is offline percival007  England
You say it reads the TOC, but does it actually Play? ie, does the Time 'tick' along?
Have you any Electronics experience, what Test Gear have you available?
Service Manual here.................
Rotel RCD-855 Manual - Stereo Compact Disc Player - HiFi Engine
Looks like it uses the TDA1541 DAC IC, nice, are you able to oscilloscope the DATA and Clocks going into this IC?
It has several Power Supplies, can you measure these with a DVM for us?
The Analogue then goes into two Op-Amps, U401/U402, these are fed by +/-15V, can you check these? I think the problem will lie elsewhere though as you say the Digital Out is not working also.
This is derived from U (108?) (The Manual isn't scanned very well) the SAA7220 Pin 16. Can you measure the Supplies and DATA/Clocks on this IC?
P.
Old 4th May 2016, 12:59 PM   #3
Thank you Percival for your input.
- Yes the tracks are working with time counting along on the display.
- I am a newbie DIY and I have only a Multimeter with me now.
- I never use the oscilloscope yet, and I dont know what can it do, but I can try to buy local one
- I will try to find from the service manual and will back to you, hope you will continue to help me.
Thank and regards,
Old 5th May 2016, 06:23 AM   #4
Ok, lets not worry about the 'scope just yet then.
With your Multimeter can you measure the Supplies to U108 (SAA7220)? Let's start there.
P.
Old 5th May 2016, 08:26 PM   #5
Hi Percival,
I am reading the Service manual to find the supplies to the U108. The scanned SM is too dimmed that I cannot understand or guess what it is.
Could you tell me which pins are the supplies? I attached the scanned U108 here for your reference.
Thank you for continue helping me. I am really interested to find out and learning this CDP.
Napo
Old 5th May 2016, 11:19 PM   #6
I've just measured the voltage between pins 2-3 of the U401, U402. They both show 0V, either AC or DC.
- Are the pins 2 and 3 the supply voltage for the U401, U402?
- I see they have 6 pins, but on the manual only 4 pins (1-4). Do I miss smth?
- Can you tell me how to check the supply of TDA1541 and SAA7220, how much the voltage should be?
Thank you and please keep update.
Old 5th May 2016, 11:20 PM   #7
Default U401-402
here is the extract of the U401 and 402.
Old 6th May 2016, 02:41 AM   #8
and the U301-TDA1541A. Tks
Old 6th May 2016, 11:04 AM   #9
You will not measure anything with a Meter here, these are the inputs of the IC. They are NE5532's which are 8 Pin IC's. Their Supply Pins are 4 (Negative Supply) and 8 (Positive Supply). You should expect Pin 4 to be -15Volts and Pin 8 to be +15Volts.
- Can you tell me how to check the supply of TDA1541 and SAA7220, how much the voltage should be? The SAA7220 looks like it has only one supply, on Pin 24 which should be +5Volts. The TDA1541 has several Supplies.
Pin 15 = -15V
Pin 26 = -5V
Pin 27 = +5V
If you can check those Voltages and report back, that'll be a start. If you could also check the Voltage on the KILL line. The Bases of the Muting Transistors. If these are being turned on then that would produce no O/P.
After that we really need to see what sort of signals are present and that would involve an oscilloscope I'm afraid.
P.
Old 6th May 2016, 03:18 PM   #10
I have measured some supplies:
U401 and U402 (NE5532)
- Pin 4: -15v
- Pin 8: +15v
U301 (TDA1541)
- Pin 1: +2.5v, while the manual says +5v
- Pin 15: -15v
- Pin 26: -5v
- Pin 27/28: +5v
U 108 (SAA2720)
- Pin 24: +5v
So the only difference to the manual is the pin 1 of TDA1541 which is only +2.5v
Please advise, thank you!
Rotel RCD855 no outputHide this!Advertise here!
Error on Rotel RCD855 allen6266 Digital Source 2 25th July 2014 04:42 PM
Easy way to fry Rotel RCD855 - help needed aparatusonitus Digital Source 31 26th February 2010 01:19 AM
Intermittent Output on Rotel neddyboy Chip Amps 4 26th December 2009 10:55 PM
Coupling Rotel RCD855 & Marantz CD52 Klimon Digital Source 4 18th July 2007 09:02 PM
Rotel output fuse miguel2 Solid State 3 25th February 2004 11:08 AM
Copyright ©1999-2017 diyAudio
