Marantz cd63 (cd100) problem - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 28th April 2016, 12:05 PM   #1
Default Marantz cd63 (cd100) problem
Hello to all!!
my name is ale and I write from Italy
like most of you I have the passion of hifi. It happened a Marantz CD63 (the same as the Philips CD100) but has a reading problem. The capacitors have been replaced partly by me and partly by the former owner. The disc starts to turn, you hear the noise of the laser which operates three times but not read. Going closer to cdm0 you hear a beep sound as a "din-dong".
What do you think about?
Thanks in advance!!
Old 28th April 2016, 01:24 PM   #2
east electronics's Avatar
need a new laser .. that simple ..If you find working ones please let us know Ebay is full of them but if you find one that works would be a miracle
You are looking for a VAM 1202
Kind regards
Sakis
SERVICE ΕΝΙΣΧΥΤΩΝ ΚΑΙ ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr
Old 28th April 2016, 01:31 PM   #3
Hello,
thanks! but i think that in the old marantz cd 63 ( the same philips cd100) there is a cdm0 and not cdm12 vam1202.
the cdm0 is rare in ebay.
Old 28th April 2016, 02:22 PM   #4
poynton is offline poynton  United Kingdom
poynton's Avatar
Hi.
Did you replace the axial capacitors on the CDM0 control board ?
Were the caps replaced with the same value and voltage range?
Were they replaced with low ESR or boutique caps ?
The CDM0 seldom goes wrong.
I would be very surprised if it was the laser at fault.
Do not attempt to adjust the controls unless you know exactly what you are doing and have the ability to correctly adjust the laser current.
This is one way to wreck the laser.
Andy
If it ain't broke, break it !! Then fix it again. It's called DIY !
Old 28th April 2016, 05:51 PM   #5
hello,,,
the capacitors on the CDM are 3 x elna 33uF 16v have been changed by the former owner,
One was wrong was to be 220uF, I changed it with an old philips 68uf. the
I do not know if he had also tried to modify the trimmers.
How many volts should have the laser? My laser swinging and singing "ding-dong"!
thanks!!
Old 15th May 2016, 11:17 AM   #6
Salar is offline Salar  Germany
Hello Ale,
you could do me a very big favour !
I need photos of the CD 63 Lid. Especially from the lock mechanism on the front left corner
I want to rebuild those parts for a diy project and must learn how they work.
I marked the parts with red circles on the photographs following this post.
I assume the camera on a smartphone is sufficient, but you should get close.
The photos are taken from Vintage Audio Laser:
Le forum de Vintage Audio Laser • Afficher le sujet - Rénovation Philips CD100
Here is an Article about CD 63, but my French is very rusty.
Le forum de Vintage Audio Laser • Afficher le sujet - Panne sur lecteur CD Marantz CD63 (idem Philips CD100)
Another about CD63B, very identical to CD63
http://forum.vintage-audio-laser.com...41.html#p28560
Maybe those guys can help you...?
All the best and thanks if you can make photos, Salar
Old 4th June 2016, 10:39 AM   #7
Hello Salar,
He is driving me crazy this CD player.
The CD runs but does not read, the laser emits a beep beep kind and stops.
let's see if I can help you, at least.
if you send me your email address I send you some pictures.
Old 9th June 2016, 03:43 PM   #8
Hello alecoronata,
thanks a lot for your offer. In the meantime, I got some pictures from someone else. Hope you get your CD63 repaired!
Old 9th June 2016, 06:28 PM   #9
Try adjusting spindle height, laser current and radial offset.
Marantz CD63 (Same as Philips CD100) problem - dumbfounded crooner Digital Source 4 7th August 2015 04:26 PM
Problem with Marantz CD63 - Need help Ruach Digital Source 10 22nd April 2013 03:07 AM
marantz cd63 digital out problem dublin78 Digital Source 1 7th December 2007 01:34 PM
Original Marantz CD63 Audio Problem garyjirving Digital Source 7 15th May 2005 05:07 PM
Marantz CD63 Power Supply Problem-Help Please! KevinLee Solid State 12 12th September 2003 07:07 AM
Copyright ©1999-2017 diyAudio
