Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 24th February 2004, 07:39 AM   #1
Lyra is offline Lyra  Norway
Lyra's Avatar
Question Kwak Clock layout ???
I am about to make a board (Eagle) for my KC7 implemantation....
What will be the "best" choice of:
-ground plane on component side
-ground plane on back-side
-both.....??
I am also implementing a 74HC125 logic to be able to drive the output when the board is placed close to the DAC, and the clock is feed backwards via 50ohm coax.
Should this logic, and corresponding transistor (2N4401) have it's own +5V supply, or could I just use +5V from the clock ???????
Lyra
Old 24th February 2004, 02:15 PM   #2
Default Re: Kwak Clock layout ???
-both.....??
Lyra
Hi
You may look here for layout suggestions
http://members.chello.nl/~m.heijlige...decoupling.pdf
regards
Guido Tent
www.Tentlabs.com
Old 24th February 2004, 05:36 PM   #3
Banned
Send a message via Yahoo to Elso Kwak
Cool The Art of PCB Layout Design
Hi Lyra,
First remember electrons don't take sharp corners so avoid this situation by making rounded tracks.
http://www.audiotuning.de
(Click on Precision Clock)
To get the ground noise to an absolute minimum use a ground plane. See also:
http://www.national.com/rap/Story/0,1562,18,00.html
To quote from Audiocom:
The basic platform of Superclock II is its printed circuit board. This is formed as an extremely low impedance ground plane over which the components are placed. Very low impedance ground planes contribute to signal quality and are essential when handling radio frequency signals which are of exceptionally low distortion and phase jitter. The ground plane shields the radio circuits from the invisible capacitor formed when the board is mounted close to metalwork
Link:
http://www.1st-4-audio.com/control/n...asp?a=105&z=15
Even better go for a 4-layer board:
http://www.lcaudio.dk/com/intlcl.htm
Carbon composition resistors have the lowest inductance and should be used, preferentially in SMD format.
Also note that even a short trace on the PCB has inductance. So keep traces as short as possible, preferentially below one inch.
As for the power supply I quote from
http://www.trichordresearch.com/cdupgrades.html
Independent Power Supply available to isolate clock frequency noise from the rest of your CD player and also reduce other digital noise from the player entering the clock circuit.
Please see also:
http://www.net-audio.co.uk/clockpsu.html
Most authoritative paper:
http://www.analog.com/Analog_Root/st...nal_Sect10.pdf
(Page 17 and further)
Lyra I hope this answers your questions.
This entire post has been spell checked by Word in Windows.
Old 24th February 2004, 05:55 PM   #4
Default Re: The Art of PCB Layout Design
Originally posted by Elso Kwak
Hi Lyra,
http://www.audiotuning.de/english/index.html
Link:
Please see also:
dear all,
At the freqs the round edgess are nonsense (if you know how the currents run and which parameters affect the routing of the current).
The impedance of the groundplane is not well understood by many designers, including the Audiocom guys (see above, and realise that currents run in loops).
A 4 layer board may be needed if the clock signal runs at bigger distances, like in our DAC design. I see no reason in a clock circuit, 2 layers are enough, at least that is what my measurements indicate.
Bottom line:
Control the currents through the groundplane, by making sure they travel through the shortest portion (i.e. place decoupling cap closest to the gnd pin of a chip)
Reduce RF currents by placing series impedances in supply and clock / data lines
Organise the floorplan in a logical way so the higheste frequencies / currents travel shortest way
NEVER interrupt the groundplane
By doing so, we achieved a virtual equipotential groundplane, now connect / decouple all component references (including their ground connections) to ground
succes
Guido Tent
www.Tentlabs.com
Old 25th February 2004, 09:57 PM   #5
Lyra's Avatar
This is my PCB-design as for now.
There might be some faults here and there. Keep in mind that this is my first layout using Eagle.....
BTW: the size of the board is aprox. 50x80 mm.
If there are something that look's not OK, please shout out
Lyra
Old 26th February 2004, 07:03 AM   #6
Electrons are yellow and more is better!
peranders's Avatar
The layout seems pretty OK to me but two things:
1 those 1 uF, why don't choose small 1 uF/63 V polyester? Maybe you chould go for 10-100 nF + 10 uF?
2 The 74HC IC hasn't got a decoupling cap close to pin Vcc.
Maybe you should consider SMD because this is better in almost all resepcts and it's not particulary hard to solder. Go for 0805 parts and SOT23 transistors.
/Per-Anders (my first name) or P-A as my friends call me
Old 26th February 2004, 07:20 AM   #7
Lyra
Hi Lyra
one remarks, as my response is limitted as I do not have the schematic at hand
You place the ferrite bead closer to the chips than the decoupling caps. I'd suggest to swop these, the cap should realy be close to the chips
succes
Guido Tent
www.Tentlabs.com
Old 26th February 2004, 07:46 AM   #8
peranders's Avatar
When it comes to traces, always make them as short as possible, cut the corners also. Avoid 90 deg angles. Still I think you really should test SMD because smallness is very positive when it comes to digital circuits and oscillators. Not everything have to be SMD but resistors, < 100nF caps, transistors (regulators), IC's. The crystal can be holemounted.
Mask the groundplane in the skrew holes so the screw and/or the distance not make contact with the groundplane.
Look at the picture below.
Old 28th February 2004, 02:13 AM   #9
Lyra's Avatar
A (little) revised version......
Old 28th February 2004, 02:19 AM   #10
Lyra's Avatar
....and in more real size....
My Kwak Clock 7 zygibajt Digital Source 12 28th November 2010 02:37 PM
49.152 MHz Kwak clock okkyn Digital Source 0 10th July 2007 02:53 AM
kwak clock trouble pjoasti Digital Source 1 20th February 2007 08:01 AM
Kwak clock versus Tent clock rbroer Digital Source 22 21st September 2003 01:20 PM
help with Kwak-clock jarthel Digital Source 5 4th May 2002 04:16 PM
Page generated in 0.13962 seconds (84.29% PHP - 15.71% MySQL) with 11 queries
