Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 16th March 2004, 11:11 PM   #101
guys ... I have to agree with AMT, but for a different reason. This recent discussion should be moved to another thread ... because it's important that the info doesn't get LOST at the end of this long thread !!
I think it's a VERY important discussion ... which clocks are most important (jitter sensitive) on the various popular DACs. And although it is certainly relevant to ASRC, it's importance goes BEYOND this topic, and deserves it's own thread Agreed?
AMT - care to start a new thread, in case we can't get this section moved?
Old 17th March 2004, 02:35 AM   #102
I just checked with one of the designers of the PCM1704, he confirmed that only BCLK matters for jitter.
Mike
"Never confuse motion with action." B. Franklin
Old 17th March 2004, 02:11 PM   #103
Send a message via AIM to jewilson
Default Sampling Rate Conversion
This is a good paper on Design of Digital Systems for Arbitrary Sampling Rate Conversion
http://www.nt.ruhr-uni-bochum.de/leh.../paper_aAU.pdf
Jim W.
Old 16th April 2004, 09:51 PM   #104
jwb is offline jwb  United States
jwb's Avatar
Send a message via AIM to jwb
werewolf, this information is absolutely first rate. You've made a tremendous contribution to this forum.
I've had this bookmarked for a while, but I have a few new questions:
I have a new design that uses the TI SRC4192, which is pin-compatible with AD1896. Both have a bypass mode, where the output is copied directly from the input. I use this mode when the transport is known to be slaved off the DAC's master clock. However, because of the overall architecture, the output port clock is double the input port. So if a CD player is running from my DAC's 22.5792MHz clock, we have something like this:
Code:
CDP -> S/PDIF -> CS8415A -> 44.1kHz i2s -> SRC4192 -> 88.2kHz i2s -> DF1704 -> 705.6kHz RJ -> PCM1704
........................................^ bypassed ^
I believe that in this mode the ASRC will simply copy the incoming sample to the output port twice. Is that your thought? If so, what effect does that have on the signal? Is it neutral or detrimental to the information in the signal?
jwb
Old 16th April 2004, 10:47 PM   #105
Marek is offline Marek  Poland
No,in Bypass mode, the assumption is that the SRC4192 input and output port sampling rates are exactly the same. Therefore, LRCKI must be the same rate as LRCKO, and BCKI must be the same rate as BCKO. This can only happen if LRCKI is connected to LRCKO, and BCKI is connected to BCKO. This connection is not performed internally in the SRC4192 - you must perform the connection external to the SRC4192. The SDIN data is internally routed to the SDOUT pin, which is the definition of Bypass mode for the SRC4192
Marek
Old 23rd July 2004, 05:26 PM   #106
jcx is offline jcx  United States
Default part 3?
Where’s the jitter reduction? - promised in first post
Werewolf gives us a fine tutorial on asynchronous sample rate conversion via polyphase filtering extending over dozens of posts with perhaps one or two sentences hinting at the actual means of jitter reduction
I would like to see a similarly detailed explanation of “the real jitter reduction” – the following is my best guess based on an understanding of digital filtering and the few hints in Werewolf’s tutorial and the AD1896 data sheet
Presumably the core concept is the differential measurement of the phase/frequency difference between input and output clocks that is insensitive to the local clock running the chip, followed by the asrc translation of the incoming data to the (filtered estimate) of the output clock phase/frequency – the actual asrc process is an enabling technique, making this approach possible but asrc is not the source of the jitter reduction
The jitter reduction comes from the filtering of the “phase” (frequency ratio) estimate between the input and output clock
This is done in the digital domain so it is possible to have performance that exceeds some analog phase /frequency measurement/filtering implementations but much more information is necessary to establish the advantages/tradeoffs
This scheme clearly has some advantages (performance with wide range of input/output clock frequencies) and a few less obvious consequences; the output clock must be very low jitter since if the asrc is working with the filtered phase estimate, instantaneous output clock jitter isn’t compensated
Further, those indulging in pride of ownership over the accuracy of their output clock should realize that the net effect of this phase/frequency filtering/asrc translation process is very similar to a pll in that the incoming transport clock frequency is still controlling the effective reproduction sample rate
Old 23rd July 2004, 06:37 PM   #107
Werewolf has bailed on this thread. Maybe he was shot with a silver bulet.
Jim W.
Old 6th January 2005, 01:14 AM   #108
hey guys ... sorry to be gone for so long.
jcx, allow me to address a few of your points :
To summarize the jitter reduction we discussed on page 8, the ASRC filters incoming jitter through the long-time-constant averaging in the polyphase selection process. Remember that it's not the polyphase length, but rather number of polyphase filters that ultimately determines time base resolution (the polyphase length typically impacts transition band slope). As stated, the number of polyphase filters is huge ... selecting the correct one when an output sample is requested requires long-term averaging for precision. And this long averaging provides jitter filtering.
In the ASRC, this filtering is done purely digitally of course. Yes, the residual jitter is ultimately "mapped" to the output data ... must be, because it's not mapped to the output clock ... but the jitter filter bandwidth can be VERY low (typically only a few Hertz), resulting in a very significantly attenuated jitter, before it is mapped to the output data.
Compare to a PLL - analog filtering, tough to get a jitter filter bandwidth as low as a few Hertz without encountering other problems (VCO noise, jitter accomodation). Yes, the jitter "remains" on the output clock instead of data ... BUT, if the jitter is small enough, data & clock jitter are indistinguishable (remember, the right sample at the wrong time is the wrong sample).
BOTTOM LINE : the ASRC can reduce jitter further, simply because the bandwidth of the jitter filter is lower. And, the process is done purely digitally, meaning less chance for other noise sources to corrupt the process.
Output clock must be low jitter? You bet it does. It calls for a very clean, LOCAL crystal oscillator driving the output clock rate ... and presumably the nearby DAC as well.
Old 6th January 2005, 03:12 AM   #109
Do you have a particular ASRC in mind as it would seem they don't all work the same way.
Old 6th January 2005, 04:14 AM   #110
Well, this thread was certainly more theoretical/foundational in nature ... and no doubt some of the experts here on diy have more hands-on experience I have had limited experience with the CS8420, it's notoriously difficult to use. The new CS8421 looks better in this regard. The specs on the Analog Devices device look very good indeed. Don't know much about the TI device, other than what I've seen in the data sheet.
In addition to ease-of-use, I'd say the important specs to consider are :
1. Large Signal to (Noise+Distortion) : S/(N+D) specs, at the intended sample frequencies of interest. Look for tests performed at higher frequency fundamentals. Large signal performance is significant, because residual high frequency images (that will ultimately alias back into baseband) scale in amplitude with the fundamental.
2. Whatever specs you can find about jitter filtering ... corner frequency at different sample rates, and roll-off rate. Lower is, in general, better, but does imply longer lock or aquisition time, and slower tracking in applications with more rapidly varying input rates.
3. Standard digital filter specs like passband ripple and transition bandwidth are of course important, but stopband attenuation can be misleading. This is because in ASRC applications, it's really the total integrated stopband energy that's important, more than maximum stopband level.
Hope that helps ...
PMD100 Max Sample Rate? Filburt Digital Source 7 23rd May 2008 04:30 AM
Sample rate into BB PCM1798? Asgard Digital Source 14 22nd July 2006 12:54 PM
DSO Bandwidth vs sample rate bzo Parts 3 23rd February 2004 03:53 PM
New sample rate converters from TI hifiZen Digital Source 3 15th March 2003 11:42 PM
Copyright ©1999-2013 diyAudio
