Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Marantz CD84 tray motor dead?
Old 26th February 2016, 06:57 PM   #1
MaccAu is offline MaccAu  Australia
MaccAu's Avatar
Send a message via AIM to MaccAu Send a message via MSN to MaccAu Send a message via Yahoo to MaccAu Marantz CD84 tray motor dead?
Default Marantz CD84 tray motor dead?
Hi All
My Marantz CD84 was working perfectly a month or so ago when I lasted used it. I am wondering if the spell of humid weather has caused the problem with the playing most of the cd and returning to the beginning? maybe some oil for the swing arm mech?
Another issue is the tray wont respond. I checked all the jumpers , also took of the belt and tried to power the motor with a AA battery, but there was no respond. I had itinally thought it was the open close button on the tray??
Thank you
Sam
1980s are rad
Last edited by MaccAu; 26th February 2016 at 06:59 PM. Reason: remove moderators please put in wrong section
Old 27th February 2016, 07:36 AM   #2
sq225917 is offline sq225917  United Kingdom
Send a message via MSN to sq225917 Marantz CD84 tray motor dead?
Check there's power going to the motor. If so it should be a simple replacement, 5v mabuchi dc motor.
Paradise Pre-reg PSU PCBs
Old 27th February 2016, 09:13 AM   #3
JonSnell Electronic is online now JonSnell Electronic  United Kingdom
JonSnell Electronic's Avatar
Disconnect the motor from the logic feed before testing with a power supply of around 3volts. If no action, replace the motor. If you power up the motor when still connected, damage may occur to the driver stage.
Support for Fender, Marshall and all Valve Equipment; Audio Innovations, Audiorama FU29, Quad and Leak. www.jonsnell.co.uk
Old 27th February 2016, 08:07 PM   #4
MaccAu's Avatar
Thanks for the reply Sq, i will look out for the motor 5v dc. The CDE84 wasnt playing again so I think the cables must need checking and the seating of the connectors. Motor didnt work with 1.5v battery so it must need more juice to test
Thanks Jon, yes i disconnectred the wires to test it but not with 3v only 1.5v, I will try again if no action will replace iwth motor that SQ mentioned
1980s are rad
Old 28th February 2016, 07:31 PM   #5
kevinkr's Avatar
This thread is in the wrong place so I'm going to move it to digital source.
Edit: Moved
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 29th February 2016, 08:20 AM   #6
MaccAu's Avatar
Thank you Kevin,
After taking the CD84 partly apart, checking cables etc, the motor is now working, along with lights.
1980s are rad
Old 1st March 2016, 04:37 PM   #7
kevinkr's Avatar
That's a good ending...
Old 1st March 2016, 07:46 PM   #8
MaccAu's Avatar
Thanks Kevin then another problem arises but that is another thread which I have had help with
1980s are rad
Marantz CD84 tray motor dead?Hide this!Advertise here!
marantz cd84 tray motor dead? MaccAu Digital Source 0 26th February 2016 06:59 PM
Marantz CD84 motor spinning constantly MaccAu Digital Source 0 4th April 2015 05:58 AM
Marantz CD84 diyman Digital Source 2 22nd November 2006 03:59 PM
Marantz CD80 tray motor is running non-stop Jeph Digital Source 12 8th May 2006 02:23 PM
Marantz Cd84 chasbmwe30 Digital Source 15 29th January 2006 11:12 AM
Copyright ©1999-2017 diyAudio
