USB NOS DAC - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 25th February 2016, 07:33 AM   #1
tedkok is offline tedkok  Hong Kong
Default USB NOS DAC
I am planning to make a USB DAC system using XMOS and NOS discrete R2R DAC that can accommodate up to 24 bit 192 Kbit/s with digitally controlled R2R output volume control. JFET output buffer. Wondering if anyone will also be interested ?
Old 25th February 2016, 10:22 AM   #2
Overkill Audio's Avatar
Default Board without power supply is good.
Hi Tedkok,
Yes I would be interested.
I am interested in a DAC / remote volume solution that can be implemented in an active monitor system.
USB input is good, but we also require 12s, AES and SPDIF inputs as well.
I have my own very high quality DC power supply available to the board so I would not want to a high end power supply as this would be a waste of money and board space for me. I can supply pristine DC at whatever voltage is required.
Thanks and all the best
Derek.
" This is not the end, not even the beginning of the end, but it is the end of the beginning "
Sir Winston Churchill 1943
Old 25th February 2016, 10:26 AM   #3
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
I'll certainly be interested in the design of the R2R DAC.
The heart ... first dictates the conclusion, then commands the head to provide the reasoning that will defend it. Anthony de Mello
Old 20th June 2016, 03:15 PM   #4
Thanks for the message. After some deep thinking, I considered that it will be safer to design the USB DAC using off the shelf DAC first, before moving to discrete component R2R DAC.
I am working on the first design
XMOS (XU208) based USB interface
with DAC of my choice, but will also need you guys' recommendation.
Should I work with a ESS9018Q2M, or dsd1973?
Both support DSD, and 192KHz 24bit PCM audio.
Any suggestions?
Old 28th June 2016, 04:47 AM   #5
baek47 is offline baek47  Denmark
Hi
I just connected a X-1 XU208 XMOS USB from I2S (not spdif) to an old philips tda1543 (pulled from a old cd). There is music.
Just struggling to get my raspberry to recognize the USB Card.
Old 12th October 2016, 12:53 AM   #6
After some struggling, a XMOS XU208 + ESS9018 DAC module as the first step.
The module contains all the power management circuit, TCXO, such that it works with a single 5V (USB power), and the following control
1) BT, analog, USB input selectable
2) APPLE/Android input selectable
3) USB and two buttons ESS bit perfect vol. control
4) USB and button Mute control
There is external relay control pin from XMOS to allow selectable output between ESS DAC output and an analog source
The volume and mute control is UAC 2.0 compatible, or through buttons connected to XMOS
The XMOS software is under development, hopefully to update you within this month.
I was wondering if anyone would be interested to purchase this module if it has a price tag of USD40 + shipping?
CS4397 NOS USB DAC Idea Rulek Digital Line Level 3 26th July 2014 10:22 PM
FS: AudioSector NOS-USB Dac Tea-Bag Swap Meet 0 15th August 2010 10:53 PM
USB interface NOS DAC?? sbrtoy Digital Source 25 7th May 2007 05:14 PM
USB powered NOS USB DAC with built-in headphone amp dsavitsk Digital Source 15 10th August 2006 06:11 AM
Tda1541a Nos-usb-dac dsavitsk Digital Source 9 12th April 2006 06:48 PM
Copyright 1999-2017 diyAudio
