diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Digital Source (http://www.diyaudio.com/forums/digital-source/)
-   -   I/V conversion idea (http://www.diyaudio.com/forums/digital-source/28720-conversion-idea.html)
Bernhard 22nd February 2004 11:23 AM
I/V conversion idea
just a very vague idea and maybe nothing new:
How about connecting the DAC output to the output of an op amp ?
The op amp output provides virtual ground, it's + input is tied to ground.
Voltage swing is seen across resistors in the op amp rails.
Bernhard
Tube_Dude 22nd February 2004 12:16 PM
Re: I/V conversion idea
Bernhard
I think that it will work...try it!!
Tell us about the sound quality :)
PS: The output is even balanced...i'm curius!...:whazzat:
Bernhard 22nd February 2004 12:35 PM
Just how to control offset ?
Tube_Dude 22nd February 2004 12:37 PM
The opamp must have the feedback resistors...as usully...only nothing connected to the input...;)
Bernhard 22nd February 2004 01:40 PM
2 Attachment(s)
I meant the I/V output, not the input...
A quick & dirty schematic, the 3,75k used to simulate the 4mA current.
Again, maybe nothing new but as I am new to I/V, I don't know.
Can be built discrete too and without output cap...
Comments :confused:
Tube_Dude 22nd February 2004 01:54 PM
Again, maybe nothing new and can be built discrete too and without output cap...
Comments :confused:
I was thinking that that the current output of the dac was connected straight to the op amp output...
that way no offset to care...and the output will be in resistors in series with supply pins of the op amp...;)
Bernhard 22nd February 2004 02:00 PM
Yes, I was thinking like this too, but then the signal is cut in positive and negative halfs and has to be put together again somehow.
On a sine current input there will be only a positive halfwave on the positive rail resistor.
And negative rail resistor respectively.
Tube_Dude 22nd February 2004 02:03 PM
Not if you force the op amp to work in class A by a pull down resistor from the power rail ...;)
mikelm 22nd February 2004 02:18 PM
Biasing the op amp into class A with CCS at the o/p will give full o/p on one of the supply lines.
mike
just realised this will not be practical - tube dude's idea may be better
Tube_Dude 22nd February 2004 02:20 PM
mike
Yes...the CCS is even better than the resistor....and will inject much less suplly noise! :)
Resources saved on this page: MySQL 18.75%
