I/V conversion idea - Page 2 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 22nd February 2004, 06:05 PM   #11
Ryssen is offline Ryssen  Sweden
Ryssen's Avatar
Biasing the op amp into class A with CCS at the o/p will give full o/p on one of the supply lines.
How is this done???
Old 22nd February 2004, 07:22 PM   #12
mikelm is offline mikelm  England
Send a message via Yahoo to mikelm
Originally posted by ryssen
How is this done???
Actually the more I think about it the more I think I will stop thinking along these lines and focus more on the jocko/rudolf designs.
an example of how to bias op amps into class a is shown here.
http://www.diyaudio.com/forums/showt...129#post327129
This approach to the above cct would mean that all of the current cycle would be drawn from one leg but when I was thinking on how to best convert this to a voltage I quickly came back to the jocko homo grounded base I- V i/p stage which makes the chip rather redundant.
that's my halfpenny worth
mike
Old 25th February 2004, 09:53 PM   #13
Bernhard's Avatar
Version with ccs. Works as does the one with transistor stage.
The output swings 5.5V to 9.5V.
What you all think ?
By the way if I put in NE5532 there are currents coming out of nowhere
Is it a bug in the spice model ?
Old 25th February 2004, 11:46 PM   #14
is that op amp stable without .1uF from the supply pins to earth ?
If not what do the caps to to the o/p frequency response ?
mike
Old 26th February 2004, 07:10 AM   #15
Bernhard's Avatar
No idea, but one amp that I had built with output devices driven by op amp rails was stable even with fast cfb op amp.
Anyway the resistor can be mounted close to the op amp and so can be the decoupling cap.
Old 28th February 2004, 08:07 PM   #16
Bernhard's Avatar
How about this one ?
Two inputs, each for one or more TDA1541.
An idea! Fully balanced TDA1541A DAC idea. Please comment! cartman Digital Source 8 17th July 2007 08:18 AM
idea: Cheap Dolby Digital Receiver Conversion nobody special Solid State 6 12th February 2003 07:12 PM
I/V conversion J Chen Pass Labs 2 10th July 2002 10:57 AM
D1.I/V conversion nar Pass Labs 2 20th April 2002 10:46 AM
Copyright 1999-2017 diyAudio
